Need Help Diagnosing Florescent Light Problem - Electrical - DIY Chatroom Home Improvement Forum
Old 09-15-2011, 11:25 AM   #1
Need help diagnosing florescent light problem
In my kitchen is a large (30"x30") ugly ceiling fixture with two U-tubes and what I think is a combo starter/ballast. There are no separate starters visible. When I first turn it on in the morning it does not start. I need to flick one of the switches (it is on a 3-way) on/off a few dozen times before it will finally completely light. Sometimes it partially lights or briefly flashes.
Here's the useful finding: once I get it lighted if I leave it on for a while and let it "warm up", it turns off and back on just fine, but if I turn it off and come back some time later it puts me through the original aggravation all over again.
Any suggestions on what I need to replace to get it working properly? Thanks.
Apesbrain is offline   Reply With Quote
Old 09-15-2011, 11:32 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 478
Try new lamps first.
Old 09-15-2011, 11:46 AM   #3
Really? Everything I've read says the bulbs are the least likely problem. Then again they are also the easiest/cheapest thing to switch out so I'll give it a try.
Old 09-15-2011, 01:10 PM   #4
Rewards Points: 1,512
Not to say that the ballast could do the same thing but, aged lamps will restart more readily when physically warm.
In general, fluorescent lamps, even new ones, have a harder time starting when really cold such as outdoors in winter.
Old 09-17-2011, 01:04 AM   #5
What you have is a dying breed. Rapid Start lamps and ballast. First off, your ballast is failing. Second, do yourself a favor and swap them out for electronic T8 Instant Start lamps and ballast.
uconduit is offline   Reply With Quote
ceiling fan light problem darren260 Electrical 8 03-04-2011 08:17 AM
Snowblower light problem. honeyboy 18 Landscaping & Lawn Care 7 01-20-2011 07:19 PM
Problem Wiring A Porch Light AuD14 Electrical 5 10-31-2010 10:09 PM
Outdoor Sensor Light Problem Chadi Electrical 2 07-04-2010 10:42 AM
Problem Updating Old Fluorescent Light starfishnc Electrical 4 10-26-2009 07:49 PM
