Need Help For Circuit Panel Question - Electrical - DIY Chatroom Home Improvement Forum
Old 10-09-2009, 08:48 PM   #1
Need help for circuit panel question
I try to help my friend to hook up a new circuit breaker for his dryer. His main circuit panel has 2 empty slots (K/N) and the recent electrician left the label "Do Not Remove these K/N". Is it OK to use this slots ? and why the electrician placed that label there ? if it's not OK then could I add a sub-panel and how many Amp?
Thank you very much
vpahandyman is offline   Reply With Quote
Old 10-09-2009, 08:54 PM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Originally Posted by vpahandyman View Post
.......and why the electrician placed that label there ?........
It is time to call that electrician back
Disclaimer
& Stay Safe
.....Bob Lavery
Old 10-09-2009, 09:04 PM   #3
300zx's Avatar
Post
Turn off MAIN Breaker and remember there is still HOT wires feeding the main Breaker Take cover off and inspect to see if you have busbar there what the breakers hook to.The only time I put Do Not Remove these K/N on the cover is when threre is no busbar for the breaker to hook to. Or the main is sideways and you will see the back of the breaker.
300zx is offline   Reply With Quote
Old 10-09-2009, 09:14 PM   #4
Thank you very much 300zx. I will check it out myself.
Well, the information is from my friend and also thanks a bunch PaliBob
Service Panel Question??? sv123 Electrical 4 10-06-2008 06:26 PM
main breaker panel terminology question! jeffjohnson1 Electrical 3 09-30-2008 08:04 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 03:03 PM
Question on Raised Panel Cabinet Door orange Carpentry 2 03-13-2008 06:28 PM
3 phase panel question curse21 Electrical 2 08-18-2004 10:17 PM
