Old 07-09-2011, 02:31 AM   #1
need help with ceiling fan installation
I bought a 44 inch hunter ridgefield ceiling fan from lowes. I have problems installting it as my outlet is round and does not have any holes in it.
I am not able to mount my ceiling base to my outlet. do I need to remove my round outlet with an 4 x 1 1/2 octogonal outlet?
It said 90% pre-assembled, so I thought everything should be easy.
Please help me with how to remove and install the outlet box.
do you have any step by step instruction for this ridgefield fan.
handyman4myhome is offline   Reply With Quote
Old 07-09-2011, 05:36 AM   #2
Electrical Contractor
kbsparky's Avatar
Most likely, you have an older type ceiling outlet box that was supported by a fixture hickey in the middle.
This type of box is not suitable for ceiling fan support.
Depending on how that box is fastened to the framing of the ceiling joists, it could be a simple matter of using extra long screws to fasten the fan bracket to some wood structure above the box. Just install the screws beyond the box's edge and up into the wood above.
If there is no wood structure above the box, you may have a situation where the hickey mount was attached to a thin metal bar stretched between 2 joists. If that is the case, you may have to tear that out, and use an expanding fan support box/system in its place.
-KB
How do you ground a ceiling fan installation involving a metal box? WillK Electrical 2 01-25-2011 09:41 PM
Level 5 finish expectations? Cracked ceiling.....input needed please! HeatherJ Drywall & Plaster 6 01-14-2011 06:04 PM
ceiling fan installation problems HELP! ldld2320 Electrical 12 03-15-2010 11:59 AM
More Basement Dropped Ceiling Installation Questions markronz Remodeling 7 02-28-2010 04:47 PM
Ceiling Fan Installation kennykenny Electrical 14 07-08-2008 11:57 PM
