Need Help Buying A Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 08-27-2009, 04:06 PM   #1
Household Handyman
Rewards Points: 1,408
Need help buying a switch
I'm wanting to buy two (2) of the Mark Time series 42 time delay switches to put in my bathrooms and can't find a place to buy them. These switches allow you to turn off the bath light but will allow the exhaust fan to continue to run for a pre-set amount of time for proper exhaust of humidity. Phone calls to H.C. Cramer/Mark Time company and they give me the wholesale houses which require a minimum order of ten (10) pieces @ $63 per, not what I want. Local electrical supply houses will not order less than 10 either. Anyone have any suggessions as to how a homeowner can buy two of these timer switches? Thanks , David
Old 08-27-2009, 04:35 PM   #2
Electrical Contractor
kbsparky's Avatar
Simply replace your fan switch with one of these: Available at most home-horror stores.
-KB
Old 08-27-2009, 04:36 PM   #3
WaldenL's Avatar
Rewards Points: 268
Like this one....
http://cgi.ebay.com/Marktime-Ivory-F...3286.m20.l1116
WaldenL is offline   Reply With Quote
Old 08-27-2009, 04:42 PM   #4
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
David, I suggest Westside Wholesale here in LA.
They have a help desk search function where they will search large wholesalers across the country to see whether or not any are in stock, then arrange a direct ship to you.
http://www.westsidewholesale.com/helpdesk
Disclaimer
& Stay Safe
.....Bob Lavery
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
single gang single pole switch on fan fabian Electrical 14 03-05-2009 01:11 AM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
