Need Help, Breaker Unstable - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-08-2009, 08:24 AM   #16
Electrical Contractor
kbsparky's Avatar
Originally Posted by Atroxx View Post
@kbsparky: The fixtures are wired using an electricians loop, so a single bad fixture shouldn't be causing the problem.....
Since you later disclosed that the entire thing was in a metal conduit system, this makes perfect sense. The sparks were coming from the fittings of the conduit, not out of the fixtures themselves.
This condition makes one ponder about the effectiveness of using metal conduit as your only source for an equipment grounding conductor. While recognized by the Code as compliant, I prefer to use a supplemental EGC if the metal conduit system itself is isolated.
-KB
Old 08-08-2009, 10:53 AM   #17
Originally Posted by G17GUY View Post
lol, you keep a hair dryer in your bag?
I keep forgetting it so I have to borrow one from the HO. They're less bulky [the dryer, not the home owner] than a toaster oven.
I do have a 100w 100Ω rheostat some guy gave me for free at a Hamfest. Unlike an incand. bulb, its resistance does not depend on the current through it. It might stand 5A for a few seconds but I don't want to push my luck.
I'd like to get an air-cooled water heater element for a heavy 240v load but it's just too inconvenient.
Pulling a lot of current from wiring is a stress test and weaknesses [bad neutral, bad wirenuts] show up as too much voltage drop.
Or just buy Ideal's #65-165 tester. When it pulls heavy current for testing it's only for a short pulse so they don't need air cooling or a big heat sink.
If not, you go low-tech and carry a calculator around, like me. A meter that can display 123.45v, 4-1/2 digits, 20,000 counts, also comes in handy.
Breaker problem jdhar Electrical 11 06-10-2009 01:18 AM
Sq D Trillaint Breaker problem jmreynol Electrical 3 04-28-2009 07:06 PM
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 05:55 AM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 08:59 PM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 05:44 PM
