Need Help On Breaker Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 06-18-2012, 10:36 PM   #1
Need help on breaker panel
Ok, a year or so ago some "electricians" upgraded my dads service from 100 amp to 200amp, these guys really butchered this job up but the worst thing they did was locate the panel DIRECTLY UNDER A TOILET FLANGE....a toilet flange that has been there since 1962.....and it was leaking (not at the time they installed the panel but shortly after i guess)....anyway , water ran down and in the panel, main breaker is corroded pretty bad as is the first 5 or 6 breakers so im wanting to put in a new panel....my question (yes, i finally got there) is if i mount a new panel close to the old one can i somehow jump power to the new one while i move stuff over? The reason is this will take me a VERY long time as i just have to do it one wire at a time and untangle their mess at the same time and i didnt want power off to his house that long.......
Budule is offline   Reply With Quote
Old 06-18-2012, 10:59 PM   #2
bbo
depending on your location, you wouldn't be able to work on someone else's house unless you were licensed electrician.
you will most likely have to get the poco out to shut off the power while you move the power from one to the other.
someone will chime in though about code and jumping power from one box to another.
bbo is offline   Reply With Quote
Old 06-19-2012, 09:38 PM   #3
ok, well i guess i'll figure it out somehow.....thanks anyway.....
Old 06-19-2012, 10:20 PM   #4
joed's Avatar
Rewards Points: 12,388
I think I would probably power up the new panel and then run a feeder to the old panel while you move circuits over to the new one.
breaker panel Ehren51 Electrical 3 01-20-2015 05:23 PM
Main Service Panel to 2 breaker panels - I can imagine you all rolling your eyes kalus Electrical 22 03-23-2012 02:09 AM
Modify a breaker panel cover. rrolleston Electrical 14 03-10-2012 05:59 PM
Mounting a generator inlet to the breaker panel erickotz Electrical 2 06-21-2011 12:54 AM
200A upgrade and move, backfeeding permitted? WillK Electrical 3 05-30-2011 08:00 PM
