Need Help With Air Cond. Condenser Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 05-15-2011, 07:41 PM   #1
Need help with air cond. condenser wiring
I'm wiring up a new central air condensing unit and need to know what I can use on the backside of the disconnect box to feed the 10-3 wiring through the new stud wall.
I have pulled the 10-3 wire along the crawl space and brought it up the wall along a stud and would like to terminate it inside the disconnect box. The wall is made up of 1/2 OSB, 3/4 foam, and the vinyl siding that's 3/4 in. thick.
What type of fitting / clamp do I use to enter the backside of the box to go through the wall with that will be water tight also?
Thanx
RROADHOGG is offline   Reply With Quote
Old 05-15-2011, 07:52 PM   #2
Missouri Bound's Avatar
Use a UF cable watertight connector. It's basically a compression fitting for cable with a rubber and nylon insert.
Old 05-15-2011, 08:47 PM   #3
Electrical Contractor
kbsparky's Avatar
Why did you install 10-3 cable? Does your equipment need both 120 and 240 Volts to operate?
You can bring ordinary romex into the back of an outdoor box, if it's fed directly thru the wall, and no part of the cable is exposed to the weather.
You can use a simple plastic NM bushing/connector like this one:
Or this one:
-KB
Old 05-15-2011, 09:00 PM   #4
Rewards Points: 6,652
Sparky, possible they have the disco with the 120vac GFCI courtesy outlet in it. That one costs a little more.
Condenser Fan Motor Wiring frito HVAC 15 06-22-2016 04:06 PM
wiring my condenser fan to my central air unit 45lonnie Electrical 1 09-05-2010 10:52 AM
Goodman Fan Condenser Replacement Help bigjohnstud4200 HVAC 2 07-03-2010 02:54 PM
Wiring Help air cond compress not running! milender HVAC 5 05-06-2009 11:00 PM
Wiring a 1/4 condenser motor. kramnation HVAC 15 10-31-2008 11:27 AM
