Need Help. 4th Story Outlets Went Out - Electrical - DIY Chatroom Home Improvement Forum
Old 12-12-2010, 02:20 AM   #1
Need Help. 4th story outlets went out
I live in a four story house, with a basement as the bottom floor and 2 single bedrooms on each side of the top of the staircase on the fourth floor. the outlets in each bedroom stopped working, but the lights both in the bedrooms and the staircase hall work. How should i go about fixing this?
hyde0044 is offline   Reply With Quote
Old 12-12-2010, 07:25 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,948
Well, since you give absolutely no clue as to your electrical experience I'd say calling an electrician is your best bet.
Old 12-12-2010, 10:28 PM   #3
Scared Electrician
Saturday Cowboy's Avatar
I have to agree with pete
I am assuming that you have checked for trippped breakers(keep in mind the handles sometimes stick) that you do not have a tripped GFI,
Then you need to deturmine which circuit it is an how the circuit is routed in the home. At which point you can begin to look for the point of failure.
Don't forget to turn off power and to check that stuff is dead before working.
Saturday Cowboy is offline   Reply With Quote
2 wire outlets: connect neutral to ground? border collie Electrical 19 04-12-2013 12:29 PM
Need to rewire outlets and lights..HELP suboveryde Electrical 1 11-02-2010 06:19 PM
Replacing kitch outlets to GFCI jhubert Electrical 7 11-16-2009 07:23 PM
outlets work, but barely (?) joeyboy Electrical 7 08-27-2008 08:37 AM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 01:55 PM
