Need Help With 4 Way Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 02-22-2011, 01:32 PM   #1
Need help with 4 way switch
I have two 3 way and one 4 way switch. I have simply replaced the old ones with new decorative ones and now they stopped working properly.
3 way switch works only if 4 way switch is turned on.
What could i have done wrong?
charlesh is offline   Reply With Quote
Old 02-22-2011, 01:37 PM   #2
Licensed electrician
Rewards Points: 1,876
Somewhere you have transposed a wire. On the 3w one screw should be an odd color. You also need to pay attention to the pairing on the 4w switch. Sometimes it is top/bottom, others are left/right.
You can see if the 3w's work properly by removing the 4w and wire nutting the cable thru the 4w box.
charlesh (02-22-2011)
Old 02-22-2011, 01:48 PM   #3
thanks Jim.
I know the problem is with 4 way. Since everything worked fine when I replaced 3 way switch. One wk later, I replaced the 4 way switch and this problem started.
Old 02-22-2011, 02:20 PM   #4
Try to see how you have the travellers from each cable paired. Switch to another combination, but keep the pairs together.
Old 02-22-2011, 03:39 PM   #5
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
Some 4 way switch switch top to bottom, and some side to side.
Look at the diagram for the switch you installed and pair the wires to the diagram.
jbfan is online now   Reply With Quote
Old 02-22-2011, 04:45 PM   #6
Rewards Points: 83
Take a look at this drawing and see if it helps any.
davido30093 is offline   Reply With Quote
Wiring in a 4-way Switch RickSene Electrical 6 05-13-2017 04:29 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
1 pole + 3 way switch momof2labs Electrical 1 05-22-2010 10:37 AM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
