Need Help With 3-way Switch Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 02-18-2013, 06:21 PM   #1
Need help with 3-way switch circuit
Hi, I have this 3 way switch currently:
I want to add a standard receptacle between the 2 lights. How do I wire that (so that they all turn off/on at the same time)?
Thanks,
modelmanjohn
modelmanjohn is offline   Reply With Quote
Old 02-18-2013, 06:26 PM   #2
deverson's Avatar
Rewards Points: 77
Parallel off one of the lampholders.
deverson is offline   Reply With Quote
Old 02-18-2013, 06:27 PM   #3
joed's Avatar
Rewards Points: 12,940
Connect the receptacle into any place on cable 2 between the lights or run a new cable from either fixture connecting it to the same black and white wire that is connected to the light.
Old 02-18-2013, 07:31 PM   #4
thanks. Quick question: it must be line #2 between the lights? Or could it be either line #1 or #2 (the 14/2 lines).
Old 02-19-2013, 06:43 AM   #5
Rewards Points: 2,516
try this: ground wire not shown for ease of drawing
hammerlane is offline   Reply With Quote
Dimming lights on one circuit, GFCI breaker tripped boatman537 Electrical 4 06-05-2012 10:43 AM
Kitchen circuit re-design - Existing is a mess darlingm Electrical 5 12-31-2011 09:45 PM
Ceiling Fan Circuit Problem G_S_DB Electrical 1 08-25-2010 06:24 PM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
Adding a switch and new lights to a circuit? mj876 Electrical 5 03-07-2010 04:10 PM
