Old 03-03-2012, 08:55 PM   #1
Need help with 220/240 wiring
I just bought an air compressor and need to wire it up. I think it should be simple but i want to make sure i am using the right stuff.
I bought a plug from my local ace. I think it is for an oven but it has 3 wires and my air compressor has 3 wires and my plug in has 3 wires so im thinking i should be able to make this work.
My air compressor has a white, black and a green. The plug has no colors but the instruction say the top pole is white but i think that is where i would put the ground. My house has a black, brown and a bare wire(ground)? I would think it would be simple but the question i have is the plug says its not for a grounded system? I don't get it.
Any help would be appreciated.
Here is more info;
Basicly i am gonna wire Leviton 800-5206 Flush Mount Range Outlet 3 Pole - Blackthis recepticle and use Ace® 3 Wire Dryer Cord - Replacement Electrical Cords - Ace Hardwarethis to connect to my air compressor.
I hope those links work lol
wraptorman is offline   Reply With Quote
Old 03-03-2012, 09:14 PM   #2
Hold up, you have the wrong plug. someone will be with you in a min. and get you straight.
There going to need to know how many amps the compressor is.
Old 03-03-2012, 09:17 PM   #3
MarginallyQualified
Is there something OTHER than this (typically 120V set up)...
that has told you to use a 240V supply power?
Which then gets to the next level of "rating plate data"
to see exactly what the amps (and volts) are.
Old 03-03-2012, 09:42 PM   #4
The compressor motor says it is 16 amps. Also the wire i have is Cerrowire 10/3
Old 03-03-2012, 09:46 PM   #5
retired elect/hvac/plumb
plummen's Avatar
Is there 2 differant wiring diagrams on the motor,1 for low voltage(120v) and another for high voltage(240v)?
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
The Following User Says Thank You to plummen For This Useful Post:
SD515 (03-03-2012)
Old 03-03-2012, 09:50 PM   #6
Here is the link to my compressor http://www.harborfreight.com/35-hp-6...ssor-3848.html
Old 03-03-2012, 09:52 PM   #7
Name3.5 Horsepower, 60 Gallon, 130 PSI Vertical Air CompressorSKU3848Running Amps15 AmpsAir Output at 40 PSI14.5 CFMAir Output at 90 PSI12.8 CFMTank Capacity60 gallon (US)Compressor TypeVerticalAir Stage1BrandU.S. General Air Superiority
Thermal overload protection
240 volts, 15 amps
Hardway is offline   Reply With Quote
Old 03-03-2012, 09:53 PM   #8
No its just 240
Old 03-03-2012, 09:55 PM   #9
http://manuals.harborfreight.com/man...-3999/3848.pdf
Here's the wiring diagram.
Looks like only 220 volt.
zappa (03-04-2012)
Old 03-03-2012, 10:03 PM   #10
It is a model 3848 full load amps is 16 amp requires 30 amp breaker.
Writer’s information is for discussion purpose only and should be confirmed by an independent source.
Old 03-03-2012, 10:12 PM   #11
plummen's Avatar
Well according to your picture of the dryer plug and cord you want to use Id use the top 2 connections for your 240,seperate 120v leg to each side and the bottem L shaped slot is for your grd wire.
Just like an older dryer hook up
Id run it off of atleast a 20a 240v circuit myself,10g wire run from panel to plug wouldnt be a bad thing if you ever want to upgrade to bigger compressor later
Old 03-03-2012, 10:13 PM   #12
Electrician
SD515's Avatar
Personally, I wouldn't use a dryer receptacle or cord. I'd use a L6-30R & L6-30P with a length of 10-3 SO cord.
Kyle
The Following 4 Users Say Thank You to SD515 For This Useful Post:
ben's plumbing (03-03-2012), frenchelectrican (03-03-2012), mpoulton (03-04-2012), zappa (03-04-2012)
Old 03-03-2012, 10:17 PM   #13
pullmmen you don't think the compressor may on start up pull more then 20amps?
Old 03-03-2012, 10:22 PM   #14
plummen's Avatar
Yes thats also an option,but sometimes the easier you make it for people the better.
Baby steps guys,baby steps!
The Following 2 Users Say Thank You to plummen For This Useful Post:
ben's plumbing (03-03-2012), LooseSCruz (03-03-2012)
Old 03-03-2012, 10:24 PM   #15
Not to mention the manual calls for a 30A breaker.
LooseSCruz is offline   Reply With Quote
Attic wiring - ceiling lighting uses 14/2 cable without ground darlingm Electrical 3 11-29-2011 10:01 AM
Backyard wiring questions MikeInDetroit Electrical 1 11-02-2011 10:46 AM
Landscape wiring question: GFCI and Breaker Amp MikeInDetroit Electrical 0 11-02-2011 10:43 AM
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 07:45 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 08:52 PM
