Need Help - Electrical - DIY Chatroom Home Improvement Forum
Old 06-08-2014, 02:41 PM   #1
need help
have power outside from breaker box to outside wires once hook up outside plug and plug some in power dies is it a ground or what thanks for any help
roblarissa is offline   Reply With Quote
Old 06-08-2014, 09:26 PM   #2
Rewards Points: 366
need a little more info,what size wire , where does it go. what kinda plug etc.
circuitman is offline   Reply With Quote
Old 06-08-2014, 09:51 PM   #3
dmxtothemax's Avatar
Rewards Points: 5,500
How do you know there is power there ?
What are you using to test with ?
I will bet it is phantom voltage
I will bet if you hook up any load to it, the voltage goes away.
If so ? then you really dn't have any power there.
As it is a false positive.
You most likely have a broken line.
Or incorrect wiring.
dmxtothemax is online now   Reply With Quote
Old 06-12-2014, 12:04 PM   #4
Contractor in PA
I agree with "Circuitman" and "dmxtothemax". It sounds like incorrect wiring or a defective connection or defective wire.
We would need a little more info like:
1) Is this a new or old installation? if old, how old?
2) Has the outlet ever worked?
3) Is this an underground circuit? What type of wire was used (UF ?)
4) If underground circuit, has the soil been disturbed lately (digging, planting etc)
5) Is the circuit GFI protected? If so where is the GFI device?
regards
michaelpwalton1 is offline   Reply With Quote
Old 06-12-2014, 08:58 PM   #5
thanks
thanks for the help it is a pool motor pump and just stopped working one day. i did use a volt meter to show power at motor i put new breakers in box and no change it is under ground and has been hit and re-connected a few years ago
Old 06-12-2014, 09:02 PM   #6
Rewards Points: 366
i would belive you have a bad splice. i would run a whole new line & do away with the old one.
The Following User Says Thank You to circuitman For This Useful Post:
Stubbie (06-12-2014)
Old 06-12-2014, 09:25 PM   #7
Rewards Points: 455
or, mr. obvious might say maybe the motor is bad ?
Cletis is offline   Reply With Quote
Old 06-12-2014, 10:28 PM   #8
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
It would help if you could give details. One of the problems I have with giving pool wiring advice is I need to know if the present installation meets acceptable code standards. This is no area to be less than professional in your knowledge. Power can be at the motor but as circuitman said you could have a bad underground splice (open in the wiring) not allowing a complete circuit.
I'm thinking this is an above ground pool could you post some pictures of the motor and wiring connecting to the motor. Is it hard wired ... cord and plug ... what voltage? Is the wiring direct buried or in conduit? You said you replaced breakers in the panel ...what do you mean? Was a underground splice made sometime back? Many unanswered questions.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 06-13-2014, 04:03 PM   #9
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,974
Considering this is a pool my STRONG recommendation is to have a qualified electrician look at it and fix it.
Speedy Petey is online now   Reply With Quote
