Need Help! - Electrical - DIY Chatroom Home Improvement Forum
Old 05-23-2012, 07:23 AM   #1
Tdsgraffiti's Avatar
Need Help!
I have a switch in my kitchen near the back door that is wired with two black wires, two white wires, and one red wire. I need to figure out how to wire this back to normal. This switch turns off and on an outside light and on the same wire is a receptacle. Does anyone have any idea what this guy did?
Tdsgraffiti is offline   Reply With Quote
Old 05-23-2012, 07:37 AM   #2
Licensed electrician
Rewards Points: 1,750
It may not be the wiring you expected to see but it may be correct, especially if it works.
Under long standing codes the receptacle in the kitchen should not be on the lighting circuit or vice versa.
Old 05-23-2012, 07:48 AM   #3
I forgot to mention, the switch and receptacle are both outside. The switch controls the outside light.
Old 05-23-2012, 12:05 PM   #4
You are going to need to expand on why you think this is wrong.
Old 05-23-2012, 12:14 PM   #5
Not necessarily wrong, I just don't understand how to wire it back up. I pulled the wires out and don't know where to put them back in. I wanted change the switch to a newer one. The new switch has one screw on the top left, one on the. Bottom left and one on the bottom right. So three screws total. Is this the correct switch?
Old 05-23-2012, 04:28 PM   #6
Master Electrician
if i had to guess i'd say the two wire probably goes to the plug while the three wire comes from the light, either the red or the black is the "always" hot that will get connected to the black to the two wire and a pigtail out to the switch, the other color in the three wire is your switch leg back to the light and the two neutrals get hooked together. Of course the only way to be sure is to test the wires to find out what goes where.
it sounds like the new switch you have is a 3 way switch and while it can be used as a single pole i wouldn't advise it.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 05-23-2012, 04:42 PM   #7
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,968
Screw locations are meaningless.
Post a pic of the switch and the box it is going in. This may help.
Old 05-23-2012, 09:30 PM   #8
Here are the pics, let me know if you need more
Old 05-23-2012, 10:52 PM   #9
" Euro " electrician
frenchelectrican's Avatar
Now we are getting somewhere but let me ask ya this question is both switch do control the outside luminarie ?
If that is true then you have a very good chance that you have three way switch circuit so I will post a diagram how to hook it up to simplifed it.
I am pretty sure this is a correct diagram so follow the drawing and make a note the common is dark screw that will go XX-2 NM's each end
If this not work out for some reason please stop and please post the photo of the receptale as well so we can able tell from there.
Merci,
Marc
Old 05-24-2012, 07:57 AM   #10
That would make complete sense if there was another switch. But there is only one switch. I'll try the wiring that way just incase there was another switch somewhere? Maybe? I'm so confused with this setup. Is there anyway I can cap some wires and wire it normally? Black and white?
Old 05-24-2012, 08:19 AM   #11
It worked! Thank you for all your help!
Old 07-08-2012, 12:23 PM   #12
Any one know how to change this setup from a 3 way switch, to a 2 way switch?
2 reds = live wires
Old 07-08-2012, 02:42 PM   #13
What's a "2-way" switch?
Old 07-08-2012, 07:00 PM   #14
Rewards Points: 1,644
3-way - 1 = 2-way
bob22 is offline   Reply With Quote
Old 07-09-2012, 05:54 PM   #15
Sorry, I don't fully know the lingo. I'm still learning.
I mean this was a three-way setup originally, or what looked like a 3-way setup. But I wanted it to be just a simple 2-wire setup... One black, one white.
