-   -   Need held fixing a 3 way switch wiring mess. (http://www.diychatroom.com/f18/need-held-fixing-3-way-switch-wiring-mess-171752/)
sebrous 02-12-2013 07:53 AM
In box #1 I have a one pole switch and a three way switch. In this box i have 3 cables :
14/2 that connect into the one pole switch.
12/3 that goes to box #2 where the second 3 way switch is located
12/3 that goes to my light fixture
The power that feed the 3 way setup comes from tapping into the 14/2 black wire that connect into the single pole switch in box #1.
In the box of the light fixture I got the 12/3 cable from box #1 and a 14/2 cable that must exit with power since it goes feeding a series of wall outlet that are NOT controlled by the 3 way switch.
I will spare to you the details on the actual wiring of the two 3 way switches that are now functioning but only if the two switches are on the ON position. They are not doing what they should do.
The original job has been done by the electrician who originally wired the house when it was build in 1989.
PS sorry if I made some spelling errors English is my second language.
Thanks.
Read more: http://www.doityourself.com/forum/el...#ixzz2KgyELtbG
TarheelTerp 02-12-2013 08:01 AM
Originally Posted by sebrous (Post 1115557)
The original (3 way switching) job has been done by the electrician who originally wired the house when it was build in 1989.
And it all worked just fine up until when?
What has changed or been changed since then?
hmmm...
120V power, from whatever source, finds it's way to the first 3way switch.
From there a 3wire cable runs to the second 3way switch.
From there the power finds it's way to the lights.
sebrous 02-12-2013 08:08 AM
No really working.
It is not really working how a 3 way switch should work.
If I flip the first 3 way, the light opens. If I flip the second 3 way the light closes.
The problem is that if I try to flip back switch 1 nothing happen I have to go back to flip switch 2.
It goes against the definition of a three way switch. I mean don't do it if it has to be that annoying.
sebrous 02-12-2013 08:13 AM
hmmm...
The first 3 way finds its power by tapping to the single pole switch. The power goes to the light from one of the two 3 wire cable in box #1 the second one (3 wire), goes to 3 way switch #2.
sebrous 02-12-2013 08:54 AM
Diagram
Here's a quick hand drawn diagram
http://img825.imageshack.us/img825/2909/imagekyv.jpg
TarheelTerp 02-12-2013 09:08 AM
We'll get to that.
Lets start with figuring out what WAS installed...
and what worked since 1987.
HOW did the switching work?
What has changed or been changed since you got involved?
How many switches mount into Box #1?
Are any other lights controlled from that box?
sebrous 02-12-2013 09:12 AM
Nothing changed
Nothing changed this is the original install. I don't know why but this how they originally installed it.
sebrous 02-12-2013 09:15 AM
One regular switch. The power is tapped from that switch.
One 3 way switch that control one light fixture.
hammerlane 02-12-2013 09:34 AM
1 Attachment(s)
1. what is attached to terminals of the single pole switch
2.what is the function of the red conductor at box #1 and the light fixture??
3. what does the single switch control
Also when you say the power is tapped to the 3-way switch from the single switch, do you mean the 3-way switch in the same box as the single switch is getting the power to its common terminal?
Or like in the diagram below, the 3-way switch by itself is getting the power and the 3-way with the single switch is taking the switched power to the light?
sebrous 02-12-2013 09:44 AM
The white wire from the 14/2 cable.
hammerlane 02-12-2013 09:50 AM
Is there a neutral wire anywhere in box #1? If so What cable does it come from?
What is the function of the red conductor at box #1 and the light fixture??
What does the single switch control
sebrous 02-12-2013 09:53 AM
If it help you to understand I will show you the rest of the wiring very shortly.
hammerlane 02-12-2013 10:03 AM
It may. Depends on how detailed you are with identifying hot wires and neutral wires
hammerlane 02-12-2013 10:19 AM
4 Attachment(s)
Easiest way for you to remedy this is to know how a 3-way switch circuit function. Below are 4-basic diagrams. They differ by where the power enters the circuit and the positioning of the switches.
diagram 1 is power into a switch then load-switch
diagram 2 is power into a switch then switch-load
diagram 3 is power into the load where the switches are after the load
diagram 4 is power into the load where the switches are between the load
someone from the code police may yell that some of the diagrams do not have a neutral at each switch location
sebrous 02-12-2013 10:31 AM
Here's the new diagram.
http://img189.imageshack.us/img189/1975/imagedar.jpg
