Need Of Electrician's Advice..... - Electrical - DIY Chatroom Home Improvement Forum
Old 07-07-2009, 01:13 AM   #1
Need of Electrician's advice.....
Okay, not sure if this is the place to start this thread but I'm in dire need of advice. Of course the 2 electricians I phoned didn't answer, probably because it is a Sunday so I'm reaching out to CD. We have a 30 year old house and probably with the original electricial. Now, I'm upstairs vaccuming, and the vaccum shuts off from it's outlet along with 5 other outlets throughout the house. Now normally, if a fuse blows, I just press the button in the fusebox and it goes back on. This time, none of the buttons needed to be pressed and when I went back to check all the outlets, all 5 of them are now not working. Is this something that can wait till morning until I can hunt down an electrician? Of course I'm worried about a fire with a family of six, my DH knows nothing about this issue and I'm panicked. Can anyone reassure me? Please only those that may be sure about this. Jeannie
lisasctt4 is offline   Reply With Quote
Old 07-07-2009, 01:31 AM   #2
Rewards Points: 2,350
Well, don't panic, yet. Unplug everything from the affected circuit, and turn off the circuit breaker that you think controls that circuit. No power, no problem, right. What I think you will find is a bad connection in one of the outlets that went out. The current drawn by the vacuum was the straw that broke the camel's back. Often, the connection is on the verge of reconnecting, so you may be able to locate the culprit outlet by plugging the vacuum in and turning the switch on. Then with another device, a table lamp for instance, walk around and plug it into the other dead outlets. If you're lucky, this will disturb the bad connection back to life, and you will know where to repair it.
But if you want to wait on the electrician, turn the power off to the bad circuit for the night.
Old 07-07-2009, 07:14 AM   #3
In some cases the breaker looks like it has not been tripped - but it has
So you ned to actually turn the breaker fully off, then on to reset
Unless youhave the fusebox with the little fuses w/buttons?
Old 07-07-2009, 09:40 AM   #4
Rewards Points: 246
Look around and see if you have any GFCI receptacles in the area. It could be tripped. You say upstairs vacuuming. Does that mean its a bed room. Chances are slim that you would find a GFCI in a bedroom, but you never know. Take a look around.
Old 07-07-2009, 09:47 PM   #5
Union Electrician
goose134's Avatar
Not that it helps the OP but it sounds like maybe a Pushmatic panel?
I agree with the advice given. Could have been a chronic problem leading up to a failure at a splice or connection in the circuit.
goose134 is offline   Reply With Quote
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 10:05 AM
Planning a remodel - Any advice for electrical planning? toddmanqa Electrical 7 06-08-2009 03:37 PM
Electrical Advice Caution!!! Mike Swearingen Electrical 12 03-05-2008 11:51 AM
I need advice on a flat roof Krissy Roofing/Siding 10 12-27-2007 01:55 PM
