Need Electical Help. - Electrical - DIY Chatroom Home Improvement Forum
Old 10-03-2011, 02:45 PM   #1
Need electical help.
So I am replacing an outside light on my garage with a motion sensor light There is a switch on the wall for this outlet.. The switch only works when garage light is out... My problem is, when i try to test security light, it turns on the lights in my garage and not the actual security light. Any suggestions on where to start... I hooked it up exactly the way the old light was.
HVAC GUY is offline   Reply With Quote
Old 10-03-2011, 02:50 PM   #2
joed's Avatar
Rewards Points: 12,322
Start by telling us about all the cables in the switch and light boxes.
Old 10-03-2011, 02:55 PM   #3
one set of wires ran into the switch and 2 sets of wires running into the box. This is at the end of a my house and the only electric lines in this area... the two sets of wires in the box, one is taken from each set and capped off with a wire nut, one black and one white. the others going to the light..
Old 10-03-2011, 04:56 PM   #4
joed's Avatar
You have described a switch loop setup like this diagram. However since other fixtures are going on/off with the switch I think the cables don't go where you think.
Old 10-03-2011, 08:33 PM   #5
Electrician
SD515's Avatar
Rewards Points: 504
Originally Posted by HVAC GUY View Post
...The switch only works when garage light is out... My problem is, when i try to test security light, it turns on the lights in my garage and not the actual security light.
Check the switch that controls the garage lights. I wonder if it's wired properly there, or maybe it's a 3-way switch that got converted to a single pole and didn't get done correctly. The switch that controls the outside light should have constant power. Might not be getting it correctly from the garage switch box.
Kyle
electical issue..... J man Electrical 2 08-31-2010 09:27 PM
outdoor wiring, electical outlets tripping frgwtchr Electrical 6 07-25-2009 11:56 AM
Electical Wire Near Heat Vent Glimmerman911 Electrical 2 12-18-2007 03:58 PM
Electical planning for remodel wease Electrical 10 12-09-2006 10:36 AM
New home electical cost wdsfr1968 Electrical 8 08-15-2006 06:33 PM
