Need A Decent DMM - Electrical - DIY Chatroom Home Improvement Forum
Old 09-25-2010, 10:44 AM   #1
Rewards Points: 874
Need a decent DMM
Hi;
I need to replace my (not so old) Radio Shack DMM with something more reliable.
I don't want to spend more than about $50.
I just need accurate AC and DC voltage measurements from milivolts up to about 1KV, and accurate DC current measurements from miliamps to 10A, and resistance of course.
I don't need fancy things like db, transistor tester, etc.
Can someone recommend a decent meter?
Edit: How's the Klein MM200? It has everything I need, and I can buy it for well under $50.
FW
Ultrarunner2017 is offline   Reply With Quote
Old 09-25-2010, 11:58 AM   #2
Rewards Points: 835
sounds like you've established your needs in a meter. klein is good stuff. the 1kv and 10a are both at a limit of a cheaper meter imho. i would consider a cheap built in clamp-on feature if you're in the 10a range. i like them better than breaking the circuit.
TimPa is offline   Reply With Quote
Old 09-25-2010, 01:07 PM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
1kV? I have to ask; why?
Old 09-25-2010, 01:55 PM   #4
Rewards Points: 874
I don't actually need 1KV. It's just a throwback from my old days working with high(er) voltages, as an electronics tek.
As for the clamp-on feature, I will look into it, but I have an old Amprobe that does fine in that category.
Just got back from HD. They have very little in the way of Klein meters. But they did have a decent selection of Xmas trees! Two weeks ago they had their Snow Throwers out, but now I see those are gone from the front of the store, replaced by the trees.
Edit 00:02, 9/26
Ordered the Klein MM200 from Amazon. Looked at clamp-on combo meters, but too high for my budget, and I do have a working Amprobe clamp-on so the MM200 should fill my bill, and last a while!
I should have known better than to buy the RS model. I must have paid for it what I just paid for the Klein, and now I've got to replace it after only 4 years. Never treated it bad; it just stopped working reliably about a year ago, but was able to get it to work after a few running back and forth of the selector switch, and unplugging - replugging the leads.
This was not a situation I could tolerate in electrical work, so the RS will go into the electronics heaven (or hell) depending on where my town sends electronics we recycle.
I'm sure that the Klein will work well for me for a long time. I should probably also buy a carrying case for the meter, since I will want it handy while I'm on a ladder or other tight spot.
FW
paint brand: best bang for your buck with decent quality? newbpainter Painting 25 11-10-2012 10:47 PM
Picking cabinets, does anything decent exist? 1320ms Kitchen & Bath Remodeling 12 06-08-2010 11:48 PM
Is this a decent primer for this application? bluefitness Painting 4 01-27-2009 06:19 AM
Good place to buy decent fixtures? twilightcall Plumbing 3 01-23-2008 07:23 PM
