Need Chandelier Wiring Connection Help - Electrical - DIY Chatroom Home Improvement Forum
Old 04-04-2011, 10:35 PM   #1
Need chandelier wiring connection help
In the ceiling electrical box I have :
-2 black wires already connected ( never touched ) - voltage detected
-1 yellow wire - voltage detected
-3 light tan wires - 2 voltage detected, 1 no voltage
- The chandalier has 2 wires and a grounder. What wires go with what? I also have 3 outlets and 1 light switch. The 3 outlets and light switch stopped working when I took old light down. The old light only had 2 wires and no grounder. But I do know where the grounder wire goes with new light : ). Any help would be so awesome and a life saver. Thanks in advance : )
seminole1 is offline   Reply With Quote
Old 04-04-2011, 10:45 PM   #2
" Euro " electrician
frenchelectrican's Avatar
Where ya located if you are in USA/Canada area do you have Conduit and indivual conductors if so then one set is a actual netural the light tan wire may look like white when they faded out a bit.
Can you post a photo one way or other that will help a bit.
Merci.
Marc
Old 04-04-2011, 11:11 PM   #3
chandalier wiring
I am in the US. I attached 2 photos . The 2 wires on the bottom right are the new chanalier wires in both photo's. I have a fuze box in basement. House built in 1965 with original wiring.
Need chandelier   wiring connection help-electrical-wiring-005.jpg   Need chandelier   wiring connection help-electrical-wiring-001.jpg
Old 04-04-2011, 11:14 PM   #4
- the light tan wire in the middle in first photo with the green mark is the wire with no voltage.
Old 04-05-2011, 12:02 AM   #5
Scared Electrician
Saturday Cowboy's Avatar
i'm guessing that one of the wires goes to a switch, any idea which one? how about looking inside the switch to see what colors the wires are?
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 04-05-2011, 01:45 AM   #6
The yellow one is switched while the white { light tan to OP } is netural.
If you really want to confirm this just look at the switch box and look how it connected that is the giveaway answer there.
And I am pretty sure due that is a common Chicago colour format.
If not in chicago then please post your location that will help a bit.
I have the colour code for metro Le Chicago so if you want it let me know I will post it later.
Merci.
Marc
Old 04-05-2011, 02:28 PM   #7
The light switch wire is yellow. I live in the far south suburbs of chicago. Hope that helps & is the final clues as to how I should wire the chandalier. My wife is driving me crazy with the light sitting on her dinning room table
Old 04-05-2011, 02:40 PM   #8
Ok now we know where we are going on this one.
Get the smooth chalander condcutor hook up to the yellow wire then the ribbed one { you will have to feel it to confirm or see a marking on that side is netural } and hook all the netural together then it will work and just put the wirenut back on the black one and leave it alone.
It will work that I do know for a fact due your photo help alot that make the diffrernce there.
Merci,
Marc
Note here the Chicago resdentail colour codes
White-Neutral
Grey-Dedicated neutral for GFCI
red-black -blue--Power
Brown--travelers for three way
purple--GFCI protected power
yellow-orange---switch legs
This is a typical setup.
Old 04-06-2011, 09:20 PM   #9
A picture is worth a thousand wordds. Thank you frenchelectrican for walking me though the wiring process
The Following User Says Thank You to seminole1 For This Useful Post:
frenchelectrican (04-07-2011)
Old 04-07-2011, 01:49 AM   #10
It is not a issue at all I am more than glad to help you on this one and I may suggest a idea down the road add a dimmer switch to the chalinder luminaire due some day you may want to dim it a bit for some special event.
The cost of dimmer is not that super expensive most will run anywhere from 5 to 20 Euros depending on what type of dimmer switch you want.
Merci,
Marc
Tags
chandelier , connection , wiring problem
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 08:53 AM
How to test wiring insulation? Shea_Close Electrical 13 08-25-2010 04:55 PM
Cooktop and Stand Alone Oven Wiring Replacing Existing Single Range/Stove Combination ffauth Electrical 3 08-23-2010 10:03 PM
wiring chandelier problem ljb Electrical 9 07-05-2010 06:52 PM
wiring a detached shed for AC power *and* generator backhaul wrooster Electrical 19 05-28-2010 12:59 PM
