Need Brand Recommendation For Baseboard Heaters - Electrical - DIY Chatroom Home Improvement Forum
Old 08-27-2012, 02:19 PM   #1
Rewards Points: 1,062
Question
need brand recommendation for baseboard heaters
i would appreciate some brand recommendation for baseboard heaters.
i will need one in the 8 ft range (cca 2KW), one in the 6 ft range (cca 1500W) and one little one for the bathroom in the 2ft range. the first two i plan to wire on a 30A/240V branch circuit with 10/3 cable whereas i plan to put the bathroom one on one of the existing bathroom dedicated 20A/120V circuits (i hope this is OK).
i noticed a wide deviation in pricing. e.g. QMark is 1/3 of the price of Berko but they are both made by the same company (Marley). what would be the difference? there is also Cadet, sold by Lowes and HD (which kind of scares me) which is really cheap. yet, TPI seems the most expensive (cca $400 for a 96" one while the Qmark counterpart would be $100)
thanks
Old 08-27-2012, 03:27 PM   #2
Licensed electrician
Rewards Points: 1,622
You cannot compare hydronic prices to resistance units. The hydronic is much more expensive, but the heat is more even.
The Following 2 Users Say Thank You to Jim Port For This Useful Post:
amakarevic (08-27-2012), Speedy Petey (08-27-2012)
Old 08-27-2012, 04:14 PM   #3
so you're saying hydronic is better?
Old 08-27-2012, 04:24 PM   #4
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Better? It makes the room feel more comfortable.
The Following User Says Thank You to stickboy1375 For This Useful Post:
Old 08-27-2012, 04:49 PM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
And SAFER!
The Following 2 Users Say Thank You to Speedy Petey For This Useful Post:
amakarevic (08-27-2012), stickboy1375 (08-27-2012)
Old 08-27-2012, 05:13 PM   #6
I couldn't decide either when I bought mine. I bought a couple of TPI and a couple of Marley/Fahrenheat.
The TPI with the 12-gauge aluminum housing are a bit more sturdy, but I don't think its worth the extra cost. Both seem like quality units. The TPI has the built-in (extra cost) thermostat on the front and the Fahrenheat on the side if that makes a difference to you. Otherwise, I'd say its a toss up.
Edit: mine are the hydronic units- lower surface temp/longer, "slower" heat = safer and more comfortable
jbs11 is offline   Reply With Quote
The Following User Says Thank You to jbs11 For This Useful Post:
Old 08-27-2012, 05:17 PM   #7
but they all seem to be hydronic. are QMark or Cadet resistance?
Old 08-27-2012, 05:24 PM   #8
QMark, Cadet, Farenheat, all make standard resistance heaters.
Old 08-27-2012, 06:08 PM   #9
An old Tradesmen
Rewards Points: 7,332
Hydronic/oil filled heaters take longer to warm the room, and give off heat for a longer period of time when the thermostat is satisfied, which makes the room fell more comfortable. Brand is often best selected by what is m ore common to get parts for in your area.
Old 08-27-2012, 06:30 PM   #10
Almost all electric baseboard heaters are going to be resistance type heat, That means the heat is generated by resistive heating (the element gets hot b/c of the current flowing through it). There are also electric radiant heaters, but I don't think they are normally baseboard mounted.
There are two main type of resistance baseboard heaters: Those where the element is exposed to the air and those where the heating element is encased in oil or some heat transfer fluid . These so-called electric hydronic heaters tend to have a lower exposed-surface temperature, and take longer to heat up and cool down, which people descibe as a "softer" heat. They are, however, much more expensive.
Tags
baseboard heaters
Sub-panel for 3 space heaters Daneel Electrical 15 05-12-2011 09:08 AM
I have two water heaters with the pilot shutting off randomly stanlam Plumbing 3 08-14-2010 03:57 PM
Direct vent gas room heaters jmcw HVAC 1 06-02-2010 11:55 AM
how to wire up electrical baseboard heaters mmd21 Electrical 13 12-05-2008 08:11 AM
Tankless Water Heaters Recalled for Repair Due to Carbon Monoxide shimp Plumbing 1 01-22-2008 06:52 PM
