Need Brainstorming Ideas On Hiding A Wire.... - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-16-2007, 01:13 PM   #16
Rewards Points: 256
Originally Posted by Stubbie View Post
Is this a new unit?
stubbie
Yes but I bought it through one of their independent wholesalers. The wholesaler's site says warranty is void if face panel is removed during installation or if alternate wiring is used directly into the unit (they even wax over the screws to deter you from doing it). I think I'll call the manufacturer directly and see what they say.
moneymgmt is offline   Reply With Quote
Old 10-16-2007, 01:31 PM   #17
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Ok thats cool. I just didn't see anything that showed a factory pigtail. Calling the manufacturer is a good idea and should clear things up.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 10-16-2007, 01:33 PM   #18
47_47's Avatar
Rewards Points: 44
moneymgmt,
3 permits for a water heater, that's strict. Best of luck,
Mike
47_47 is offline   Reply With Quote
Old 10-16-2007, 01:47 PM   #19
Rewards Points: 256
47 47: I called and asked: 1 electrical, 1 plumbing, and 1 mechanical for gas. I argued that they could all be lumped as "mechanical" and just buy one permit but they disagreed with me thus, we run as rebels, without permits.
Old 10-16-2007, 05:41 PM   #20
Don't forget....you need a disconnect for that beast. A non fused pullout will suffice (about 15 bucks). Branch circuit thru wall into surface mounted and pigtail into W/H.
It won't be "pretty" but it can be "clean".
Also...I'd protect the pigtail with flex.
220/221 is offline   Reply With Quote
Old 10-16-2007, 05:45 PM   #21
Rewards Points: 256
220/221: honest question, why do I need a disconnect if its wired into a breaker? Is that not the purpose of a breaker?
Old 10-16-2007, 06:51 PM   #22
Electrical Contractor
jbfan's Avatar
Rewards Points: 138
Can yoou see the breaker from the water heater?
Based on what you said, I don't think you can. The disconnect will be used as the J-box anyway.
Disconnect required!
Old 10-16-2007, 07:26 PM   #23
Electrician philosopher
As to what I think the code making panel was thinking on why you have to have the disconnect as well as the breaker is so the plumbing contractor, when he comes to service the water heater, can disconnect the electricity and be in sight of that disconnect while he is working. We wouldn't want lil' Jonny to sneek into the garage and flip the breaker while the plumber is in the basement with one hand on 120V and the other hand on a water pipe.
Andy in ATL is offline   Reply With Quote
Old 10-16-2007, 07:28 PM   #24
The breaker protects the wire.
The disco protects the serviceman.
Old 10-16-2007, 07:30 PM   #25
Rewards Points: 256
so if I'm within 5 feet of the panel you think I'm ok without the disconnect? THe wire from the unit is only 18", that's why I need a junction box in the first place, even though we're so close to the panel.
Thanks all
Old 10-16-2007, 08:01 PM   #26
Thanks all
Line of sight
Old 10-16-2007, 08:41 PM   #27
UAW SKILLED TRADES
Stubbie's Avatar
Place a locking device on the double pole circuit breaker so it can be locked out in the open position and you will not need a line of sight disconnect.
Stubbie
Old 10-16-2007, 08:56 PM   #28
Does it say that in the code book stubbie? I ain't saying it doesn't, i've just never seen it.
Old 10-16-2007, 09:08 PM   #29
Licensed Pro
See 422.31(B)
Old 10-16-2007, 09:37 PM   #30
Thanks guys, It would be cool to walk into a ratty old house to do a service call and see an OSHA approved Master Lock lock out/ tag out station.
Stove Top wire capt2 Electrical 8 10-05-2007 02:41 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 09:58 AM
ok to leave chandelier third wire unconnected? gonzales9 Electrical 5 01-12-2006 09:10 PM
Does a 6 x 12ga wire nut exist? peeks Electrical 1 10-02-2005 10:58 AM
wire size wire to 10kw furnace? lochcarron Electrical 1 04-10-2005 08:43 PM
