Need All New Switches And Plugs - What To Buy? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-26-2013, 10:12 AM   #1
Rewards Points: 173
Need all new switches and plugs - what to buy?
I need to upgrade all my switches and plus in my house (they don't have grounds on them).
I've noticed I have two options - 15amp and 20amp plugs. I've also need 15amp switches, but not 20amp switches. Does a 20amp plug need a 20amp switch?
RCGA is offline   Reply With Quote
Old 03-26-2013, 10:17 AM   #2
Rewards Points: 150
Most likely you're going to put in standard outlets. They are 15A outlets that can handle 20A circuits and 12ga wire. An actual 20A outlet has one of the prongs in the T formation, so it can take a 20A plug which has one prong sideways. There are very few things that actually use this plug, and if you had one such thing, it would most likely be best on a dedicated circuit anyways.
So... the 15A plugs (two parallel prongs and ground) that can handle 20A circuits are the standard plug and what I'd use...
{Edit}
Switches... If you're on a 20A circuit and switching the outlets on/off, then Leviton makes a 20A switch. It's like $3, not expensive.
-mike
SquishyBall is offline   Reply With Quote
Old 03-26-2013, 10:18 AM   #3
Rewards Points: 246
You need a ground wire (EGC) at every receptacle box to use three (3) wire devices.
How many wires do you have in each receptacle box?
Old 03-26-2013, 10:21 AM   #4
Rewards Points: 173
Not sure. But I know the house is grounded at the panel. I have an electrician friend who will be switching the plugs, but he wanted me to buy them first.
Old 03-26-2013, 10:23 AM   #5
Rewards Points: 173
My parents have a bunch of plugs with the notch on the side (20amp) in the kitchen specially.
Old 03-26-2013, 11:41 AM   #6
Always learning...
fetzer85's Avatar
Rewards Points: 262
I don't know anyone would go through the trouble of rewiring receptacles to include a ground and then not replace the old 2 prongs with 3 prongs.
Translation - go ahead and check to see if you have 3 wires coming in, but I'm nearly certain you'll only have 2.
fetzer85 is offline   Reply With Quote
replacing light switches and plugs. whiterozez Electrical 9 03-31-2012 01:18 PM
Face plates and plugs or switches inside -- must they match JDpenelope Interior Decorating 12 02-24-2012 10:25 PM
Confusion with three way plugs / switches grassy Electrical 2 06-03-2011 02:44 PM
Question about wiring and voltage with switches and lights rswurth Electrical 17 06-20-2010 11:12 PM
switches and plugs on same circuit-- how? cabinjunkie Electrical 18 08-08-2009 02:53 PM
