Need Advise On Receptical Change.. - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-26-2010, 05:34 AM   #16
Rewards Points: 738
Originally Posted by thekctermite View Post
If simple electrical work were only done by electricians, what good would this subforum be? With the proper homework and preparation (including permits and inspections) there are numerous electrical jobs in a home that a competent DIYer can handle.
I understand that this is a DIY forum. The point of my story is that there is "NO SIMPLE ELECTRICAL WORK". Just my opinion. You can kill someone with 120V in a bathroom more ways than I can count. You can start a fire with 120V anywhere, in a million different ways.
I don't care if people want to DIY, I was just giving one example that illustrates the risks involved in believing that anything electrical is "simple".
Mark
busman is offline   Reply With Quote
Old 01-26-2010, 05:38 AM   #17
Rewards Points: 738
Originally Posted by Scuba_Dave View Post
I've rewired most of my house, installed 3 sub-panels, a hot tub, pool pumps, GFCI & AFCI
All as DIY, its what this site is all about
Unfortunately, completion of the work and getting it to work in no way means that it was done to code. An inspection is no guarantee either. The amount of things I've seen that passed inspection with code violations could fill volumes. FWIW, an electrical contractor is no guarantee of code compliance either.
I'm not saying that what you've done isn't to code. I wouldn't know without seeing it all.
Respectfully,
Mark
Old 01-26-2010, 07:39 AM   #18
Remodeling Contractor
Originally Posted by brons2 View Post
Nobody suggested that he check to see if the (metal) box is grounded? I mean ok fat chance, but if it is he can install a normal outlet.
he mentioned that the house is using the old 2 wire Romex.... no the metal box would not give you a ground, but if used (most likely is) then this would make no difference here, but would need a ground wire to it if one was present.
Discussion on Contractor Estimates/Contracts ARI001 General DIY Discussions 19 11-25-2009 10:47 PM
Need advise for roof DIYJAY Roofing/Siding 17 05-20-2009 02:32 PM
Changing potty. Do I need to change the flange out? tarheelblue Plumbing 9 09-04-2008 11:41 PM
Need some serious advise on heating system helpless handyman HVAC 26 12-07-2006 05:28 PM
change color of flooring and other wood finishing, possible? KUIPORNG Remodeling 3 07-20-2006 06:54 PM
