Old 01-25-2010, 05:26 PM   #1
Automotive Enthusiast
Sellncars's Avatar
Send a message via AIM to Sellncars Send a message via Yahoo to Sellncars
Need advise on Receptical change..
Hello everyone,
I want to change 2 Receptacles in a bedroom, I took off the wallplate and killed the power, took one of them out and found this, No ground wire, do i have to get GFI receptacles? Sorry about the picture, I'm not an artist.
Thanks,
Sellncars
Sellncars is offline   Reply With Quote
Old 01-25-2010, 05:33 PM   #2
Remodeling Contractor
if you have no ground wire then the replacement outlets should be GFCI outlets.
Old 01-25-2010, 05:51 PM   #3
Sellncars's Avatar
I thank you very much, i just wanted to make sure before i went out and bought them.
Old 01-25-2010, 05:52 PM   #4
Electrical Contractor
You can replace it with a gfci, or another 2 wire receptacle.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 01-25-2010, 07:31 PM   #5
Sellncars's Avatar
First i must say that I'm not an electrician, but am safety conscience more so with electricity then anything else. ( I like life ). What I'm going after is more so a ground then just replacing these receptacles. Is the GFCI going to take care of Ground? House was built in the mid 50's and has wire that has like a mesh covering it, except where Romex has been added over the years.
Thanks,
Sellncars
Old 01-25-2010, 07:33 PM   #6
The ground is used to provide a more conductive path for errant current than the human. Thus you do not get the shock. But the GFI is allowed in this case since it monitors for fault currents and shuts off when one exists over a limit that will hurt you.
Old 01-25-2010, 07:34 PM   #7
Xtreme DIY'r
If you want a ground you will need to run new wire
Old 01-25-2010, 07:47 PM   #8
E-lec-tri-city
Send a message via ICQ to brons2 Send a message via AIM to brons2 Send a message via MSN to brons2 Send a message via Yahoo to brons2
Nobody suggested that he check to see if the (metal) box is grounded? I mean ok fat chance, but if it is he can install a normal outlet.
brons2 is offline   Reply With Quote
Old 01-25-2010, 07:59 PM   #9
Sellncars's Avatar
Thanks for the help everyone, Then it sounds like if it isn't broken don't fix it.
Old 01-25-2010, 08:05 PM   #10
Sellncars's Avatar
Hello,
Thanks for the thought, but not in this house, i looked and didn't see any ground wire anywhere in that small box. There are alot of things in this house that were done wrong back in the day, the wiring was apparently one of them, then the walls not being straight in areas, 3 rooms on 1 circuit, Drop ceiling in the basement not being lined up with the ceiling joist's ( Impossible to install recessed lighting in center of tiles, unless ripping it all down and redo over, had opened junction box's ( fixed now ) and so on and so on.
Old 01-25-2010, 08:10 PM   #11
Moderator
Termite's Avatar
You can install a GFCI device or a GFCI breaker. Any ungrounded receptacles that are "3 prong" grounded receptacles on a 2 wire system must be labeled with two stickers in order to be code-legal.
1) "GFCI protected"
2) "No equipment ground"
Old 01-25-2010, 08:14 PM   #12
E-lec-tri-city
I got some of that in my house too, including receptacles in two bathroom and two bedrooms on one circuit, total of about 14 and no GFCI. I feel much better now that I am redoing the whole thing.
Old 01-25-2010, 08:16 PM   #13
Master Electrician
Maybe now is a good time to tell the story of the woman getting shocked when she washed her hands in the bathroom sink:
Husband had replaced the bathroom receptacle with a GFCI in the bathroom. Metal Gem box. No ground. He thought the GFCI protected them. He crammed the big GFCI in the small box and the hot wire on the line side of the GFCI touched the metal box. Metal box was touching iron drain pipe in wet-wall. Drains are now at 120V. Supply pipes at ground potential. If she had taken a shower instead of washing her hands, she would probably be dead.
This is not a job for a DIY. There's a reason it takes MANY years and significant training to be an electrician.
Mark
busman is offline   Reply With Quote
Old 01-25-2010, 08:20 PM   #14
Moderator
Termite's Avatar
Mark
This is DIY CHATROOM, and this is a perfectly acceptable job for a DIYer. When someone's over their head that is one thing, but the OP is getting good info and doing their homework. If simple electrical work were only done by electricians, what good would this subforum be? With the proper homework and preparation (including permits and inspections) there are numerous electrical jobs in a home that a competent DIYer can handle.
Old 01-25-2010, 08:26 PM   #15
Xtreme DIY'r
I've rewired most of my house, installed 3 sub-panels, a hot tub, pool pumps, GFCI & AFCI
All as DIY, its what this site is all about
Discussion on Contractor Estimates/Contracts ARI001 General Discussion 19 11-25-2009 11:47 PM
Need advise for roof DIYJAY Roofing 17 05-20-2009 03:32 PM
Changing potty. Do I need to change the flange out? tarheelblue Plumbing 9 09-05-2008 12:41 AM
Need some serious advise on heating system helpless handyman HVAC 26 12-07-2006 06:28 PM
change color of flooring and other wood finishing, possible? KUIPORNG Remodeling 3 07-20-2006 07:54 PM
