Need Advice Wiring A Ceiling Light - Electrical - DIY Chatroom Home Improvement Forum
Old 01-27-2013, 07:27 PM   #1
Rewards Points: 160
need advice wiring a ceiling light
i have added ceiling lights in 3 bedrooms, had to re wire the outlets and run a 14-2 from light to switch. didnt have really any issues except a mess of the blown in insolation from coming up and down from t he attic.
now my question. i cut out a 4in hole in front of my front door to add a light. the switch is located next to my door which obvisoulsy is t he exterior door. i was using the remodel boxes with the expandable braces between the joices but no way i can get a drill or anything in that area to nail it but i can just buy a box with the wings. since the roof line is sooo tight to the ceiling in the corner i can not get up there to drill a new hole to fish the wire down from to get to the switch. what options do i have. i really dont want to cut the ceiling as it will hard to patch as its like the popcorn texture. i can maybe cut a chunk of the wall out, is that my only option? thanks for any advise!
jhack836 is offline   Reply With Quote
Old 01-27-2013, 07:48 PM   #2
Rewards Points: 160
here is a pic... maybe i can just run a new switch on the inside wall below my house alarm box? would that be ok to do? there isnt anything against code that says i cant put a switch there right? thanks
Old 01-27-2013, 07:56 PM   #3
Rewards Points: 13,968
A flex bit should be able to drill from inside the hole for the box through the top plate, once it's through there's a hole in the end of the bit there you attach a stress relief to and when you pull the drill bit back it also pulls the wire.
http://www.homedepot.com/h_d1/N-5yc1...&storeId=10051
Old 01-27-2013, 08:25 PM   #4
Rewards Points: 160
thanks, i think im just going to add a switch. it will be alot easier and i can pull power of the outlet that is on the return of that wall which is the basement and it isnt drywalled so i will have easy access to do what i have to do.
Old 01-27-2013, 08:44 PM   #5
Rewards Points: 160
question 1 ..what kind if NM connector is the best when adding 14-2 to a metal box so that the 14-2 isnt rubbing the sharp edge of the punch out when entering the box? i know it needs one but if a wire did come bare the breaker should trip right away too because the box is grounded, correct?
question 2... am i able to run armored cable into a plastic box or should i just get a metal box when i add my switch? thanks
Old 01-27-2013, 09:04 PM   #6
Halex clamp connectors for nm cable
http://www.homedepot.com/h_d1/N-25ec...1#.UQXqNGt5mK0
Get a metal box.
clydesdale is offline   Reply With Quote
Ceiling fan light 5-way wiring? laurenlex Electrical 3 01-20-2012 07:55 PM
confused re wiring on ceiling light stel Electrical 6 08-07-2011 02:22 PM
Wiring bath fan to replace ceiling light quinten Electrical 3 10-31-2010 06:50 PM
Tying in wiring to existing ceiling light samson115 Electrical 3 11-22-2009 12:12 PM
Ceiling Fan /w light wiring question beachbone Electrical 4 02-04-2009 10:42 PM
