Need Advice/opinions On Recessed Layout - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-16-2009, 02:00 PM   #16
got to love scissor trusses.If your going to pull power from the switch make sure they didnt send the white over hot on the plug first.
drdon51 is offline   Reply With Quote
Old 01-18-2009, 09:25 AM   #17
heres the finished product!! went pretty smooth but ended up switching the 3 inch to 4. what do you think? Thanks for the help and opinions.
satchmo75 is offline   Reply With Quote
Old 01-18-2009, 10:03 AM   #18
looks good ,Really helps define the room ,How come you switched can size
Old 01-18-2009, 10:10 AM   #19
thanks! the 3 inch housing I had were horrible to install. The design was very good and the install wasnt good so went with same halogen but 4 inch and different housing design. Went very smooth after that. The tedious part was running the wire down the wall into the recpt box.
Laminate wood floor layout questions nathan.tran Flooring 4 08-30-2008 10:56 PM
Recessed Lighting under hot/cold supplies?? KC10KEVIN Electrical 1 05-08-2008 10:21 PM
recessed lighting wiring to 3way switch DIY4EVER Electrical 1 07-12-2007 01:35 PM
Recessed light plan foiled? kcrossley2 Electrical 8 03-14-2007 11:08 PM
recessed light farrington135 Electrical 3 12-03-2006 12:02 PM
