Need Advice Installing Outdoor Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 06-09-2008, 07:18 PM   #1
Need advice installing outdoor lights
I'll be installing 4 outdoor wall lights on the exterior garage front. The wall is brick. I'm thinking I'll need to drill out a cutout in the brick to accommodate a fixture box to attach the light to.--Is that the way these installs are done? If so, I assume a hammer drill should do the trick? How heavy duty of a drill would I need and are there any "tricks" you guys might have to efficiently make this cut in the brick?
Any ideas would be appreciated.
billyg is offline   Reply With Quote
Old 06-09-2008, 08:22 PM   #2
Electrician
Personally, I would probably just install a fixture block (aka piece of ceder with a 4" round hole for a pancake box) to the brick and just drill 1 hole through the brick for the wiring method of your choice.
chris75 is offline   Reply With Quote
Old 06-09-2008, 09:36 PM   #3
I'd try to surface mount a pancake box (1/2 deep) if the fixture design (canopy depth) will allow it.
If not, bump it out like Chris suggested. It will be easier then chipping out brick.
If you MUST chip out the brick, use a 1 gang box (rectangle) and cut the sides with a diamond blade on a grinder. The height of the 1G box is about the same as a brick.
Some people would suggest that, since it is brick and can not catch fire under any circumstances, that you can simply skip the J box and make up the wires in the canopy portion of the fixture. I believe that code requires a jbox even if it is mounted to concrete covered with asbestos.
220/221 is offline   Reply With Quote
Old 06-10-2008, 08:43 AM   #4
Electrical Contractor
Try an Arlington flat surface fixture box 8161TR
www.arlnew.com
hpp58 is offline   Reply With Quote
installing a motion sensor light in a garage-need some advice mcvane Electrical 2 01-03-2008 01:48 PM
I need advice on installing self-adhesive floor tiles SavReb Flooring 2 11-20-2007 10:09 PM
Need advice on installing indoor/outdoor carpet Krichton Flooring 1 06-27-2007 04:36 PM
advice on installing equipment grounding bar in main panel pacifier1er Electrical 5 05-29-2007 06:55 PM
Installing a gas range (advice needed) Krichton Appliances 8 11-24-2006 09:20 PM
