Need Advice On Grounding - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-23-2009, 10:21 PM   #16
Rewards Points: 2,350
Cables fished into finished walls do not need to be secured inside the walls.
Old 08-24-2009, 07:48 AM   #17
Rewards Points: 6,652
If the wall is finished, how do you plan on stapling? You can staple at the top if dropped through an attic, or from the bottom if going in from the crawlspace or basement.
Old 08-24-2009, 08:37 AM   #18
So are you saying that the NEC code does not require that staples be used when cables are fished into finished walls? Great news for me is this is so.
gskywalkers is offline   Reply With Quote
Old 08-24-2009, 10:26 AM   #19
pushing my luck with the NEC
Can you run insulated or uninsulated ground conductors
under quarter round,
in grooves gouged into the drywall surface,
along corner edges (and then caulk over them)?
Old 08-24-2009, 05:38 PM   #20
Yes. The code does not require the fished wire to be stapled where it is not accessible. You do however have to staple it for the rest of the run where i is accessible.
Old 08-24-2009, 05:41 PM   #21
I will say tentatively, yes... the Code does allow for an individual ground wire to be run to a receptacle, but it must go back to the panel. It can't terminate on a water pipe or something. I would probably only do it that way in the most dire of circumstances, and if I did, I would use green insulated wire.
Old 08-24-2009, 06:44 PM   #22
Since my post, I realized that a single ground wire in the wall has free air to dissipate heat (but this wire may also be in a cable with two other wires that are warm).
But, a wire under quarter round or embedded in drywall will be insulated by the wood or gypsum.
This is a puzzling problem, and "tearing out walls" is riding on it.
Old 08-24-2009, 07:29 PM   #23
Licensed electrician
Rewards Points: 1,892
This wire would only be carrying current under a fault condition.
Old 08-24-2009, 08:09 PM   #24
Yeah, but you know how the NEC is.
Old 08-24-2009, 10:11 PM   #25
Well, thanks for all the comments. I feel much better how to go about doing this now......new wire, fish it through the walls and go to the main panel. Next step is to go buy all the material for the job.
Grounding Method Steelhead Electrical 6 02-05-2009 11:06 AM
Grounding light box n0c7 Electrical 10 10-06-2008 03:20 PM
Anyone want to take a shot at why #6 to attach antenna ground to breaker? Piedmont Electrical 44 01-08-2008 04:11 PM
NEC Question Jafsvcs Electrical 1 06-13-2007 05:45 PM
advice on installing equipment grounding bar in main panel pacifier1er Electrical 5 05-29-2007 05:55 PM
