Need Advice On Ceiling Box - Electrical - DIY Chatroom Home Improvement Forum
Old 08-28-2012, 10:22 AM   #1
Need Advice on Ceiling Box
I have a new home and trying to replace a light fixture.
I removed the existing fixture which was held in place by only one screw.
I expected to see the electrical box set up better than it currently is.
See attached image - the arrow is where the one screw was.
Do I log a ticket with my builder to get this fixed or is this standard installation for a ceiling light electrical box?
dsmiami is offline   Reply With Quote
Old 08-28-2012, 10:25 AM   #2
Rewards Points: 164
Are you sure there's not a bracket between the joists?
ryan50hrl is offline   Reply With Quote
The Following User Says Thank You to ryan50hrl For This Useful Post:
dsmiami (08-28-2012)
Old 08-28-2012, 10:27 AM   #3
Licensed electrician
Rewards Points: 1,600
There is wood above that box inline with the oblong holes. The box is held up by the center screw.
You should be able to use two wood screws to hold the fixture bracket up.
Old 08-28-2012, 10:30 AM   #4
Thanks Jim - did not know that and appreciate the assistance
Old 08-28-2012, 10:41 AM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,214
For info purposed: that box is made for a ceiling fan. The fan bracket is attached with wood screws through the 2 slotted holes. Those holes are in line with a ceiling joist.
Coastal South Carolina
The Following 2 Users Say Thank You to rjniles For This Useful Post:
dsmiami (08-28-2012), J. V. (08-28-2012)
Old 08-28-2012, 10:47 AM   #6
Thanks - I learned a lot in the past couple posts.
Old 08-28-2012, 10:49 AM   #7
Rewards Points: 160
Like this.
The Following User Says Thank You to J. V. For This Useful Post:
Old 08-28-2012, 11:07 AM   #8
A "Handy Husband"
rjniles's Avatar
Originally Posted by J. V. View Post
Like this.
John
Looks like the one he has is metal and only has the recessed electrical box on one side of the joist. Same idea though.
Old 08-28-2012, 11:12 AM   #9
Rewards Points: 160
Originally Posted by rjniles View Post
John
Just a guess. Could not tell with all the over spray.............Thanks
Old 08-28-2012, 11:15 AM   #10
One last (hopefully) dumb question
For the screws like john has in his pic. do I need to drill pilot holes first before I use those wood screws, or would you expect those to be self-tapping?
Old 08-28-2012, 12:06 PM   #11
Electrical Contractor
jbfan's Avatar
Rewards Points: 464
Self tapping.
jbfan is online now   Reply With Quote
The Following User Says Thank You to jbfan For This Useful Post:
Old 08-28-2012, 01:05 PM   #12
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
John
Its plastic, I use those all the time.
Different brand, but you get the idea...
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 08:26 AM
Ceiling condensation icemand Building & Construction 1 12-15-2009 05:16 AM
need urgent advice, ceiling paint gagaliya Painting 12 09-27-2009 02:49 AM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
Advice on tin ceiling install Jim1970 General DIY Discussions 8 07-22-2008 08:46 PM
