Originally Posted by hoethre3
Hello All,
1) will the power company have to make any changes to the existing drop?
A. It depending on the POCO regulation and how well the exsting service drop is and may have to move to diffrent location or height or both again the POCO have final shot on this one so check with them.
2) can I install a sub-panel to gain the additional amps needed and not have to replace the existing 100 amp panel?
A. The best answer is do the load demand caluations to make sure if this exsting service can handle it or not. If not will have to bump up to 200 amp servicé.
3) what method would you recommend to get a line from the existing panel around the house to the hot tub location?
A. The best way is trench it but before you actually do the trenching make sure you call the digger hotline or simauir to make sure there is no other ulities in the way and from the panel to the spa or hot tub it have to be PVC no UF cable on this part it is very specfic in the NEC{ National Electrical Code}also no bare grounding conductor as well.
4) if I am facing the cost of replacing the existing 100 amp panel with a 200 amp panel, would it be less expensive to just have the power company just drop me a completely separate service (with a meter) to the hot tub location?
A. I don't think it will really justify the cost for this set up and you will end up pay second meter for it. It is cheaper just upgrade to 200 amp service that will cover majorty of the items for common size house few case may have to use 400 A service
It is being suggested to me that I am probably looking at anywhere from $800 to $1000 to just upgrade the existing 100 amp panel to 200 am service and then probably another $1000 or more to get the hot tub wired up from the upgraded service. I need to find a less expensive method if one is possible.
The best answer is run the quoteation or bidding from 3 diffrent electrical contractors and watch the specs when they write up and the cost will varies a bit depending on location and the contractor itself.
Really appreciate any advice here. Many thanks!
My answer is typed in bold bleu so you will know where I stand with it.
And you may want to look up in the NEC code section related to the hot tubs or spa they have few items to follow and it is very specfic and also make sure this circuit is GFCI protected.
Merci,
Marc
