Old 09-19-2012, 05:42 PM   #1
Need 208V 20 amp and only have two 120v amp to work with
I have two 120v 20 amp outlets running two copiers. I need to upgrade to a 6-20R oultet. Would I have enough voltage if I took out the two 5-20Rs, somehow combine and install one line to give me one 208V 20 amp outlet? I have no extra capability to add another line because I am maxed out of power coming into building
Greg Hovde is offline   Reply With Quote
Old 09-19-2012, 05:49 PM   #2
Julius793's Avatar
What do you mean you are maxed out of power? And this a single phase or three phase building?
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 09-19-2012, 05:54 PM   #3
Code05's Avatar
DIY and 3 phase questions...never a good thing.
Code05 is offline   Reply With Quote
The Following User Says Thank You to Code05 For This Useful Post:
stickboy1375 (09-19-2012)
Old 09-19-2012, 07:34 PM   #4
Master Electrician
How did you get from a 6-20r to 208 volts?
brric is offline   Reply With Quote
Old 09-19-2012, 09:26 PM   #5
If both of these outlets originate from the same hot line in the panel,
Then NO ! you cannot get 208v.
Only if you have two different phases / hots in your panel.
How many main supply wires come into your panel ?
Look at your main switch.
Be super careful !
If not confident to do so !
THEN DONT !
dmxtothemax is offline   Reply With Quote
