Need 120 Receptacle For My Washing Machine - Electrical - DIY Chatroom Home Improvement Forum
Old 10-04-2011, 07:22 PM   #1
Need 120 receptacle for my washing machine
I just removed a defunct washer/dryer combo in my condo. I bought a new LG stackable washer and dryer to go into the same small closet. The problem is that there is no 120V receptacle in the closet for the washer, just the 4 prong receptacle the old washer/dryer unit was plugged into. Is it possible to install a 120 receptacle off of the neutral and black wires in the dryer receptacle?
Jim Cherry is offline   Reply With Quote
Old 10-04-2011, 07:59 PM   #2
Rewards Points: 1,532
Only if the dryer receptacle is removed and the breaker replaced with a 20 amp breaker. No lights and no receptacles in other rooms may be added to the black wire of that circuit.
(The red wire may be used for any other kind of 20 amp 120 volt circuit and share the white wire.)
This is not really recommended since the next owner of the house may want a dryer circuit. Stringing a new 120 volt 12 gauge circuit is preferable.
The actual requirement for a laundry area is an exclusive 20 amp 120 volt circuit with receptacles intended for a washing machine and/or a gas dryer. There may be receptacles served by other circuits in the same room or area.
Old 10-04-2011, 09:21 PM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,226
I think the OP means he needs a 120 volt receptacle in addition to the existing 4 wire dryer receptacle. A stacked washer and dryer are 2 separate machines each with their own cord.
No, you can not tap off that circuit for a 120 volt receptacle. you need to run a new cicuit from the breaker panel and it must be GFCI.
Coastal South Carolina
Old 10-04-2011, 09:27 PM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 530
Unless there is a sink close by, no need for gfci protection.
Old 10-05-2011, 04:13 AM   #5
Rewards Points: 150
Really? Interesting. Do you have a article for this?
Sunny B. is offline   Reply With Quote
Old 10-05-2011, 04:38 AM   #6
Code05's Avatar
Rewards Points: 1,104
GFCI
210.8(A)(7) Sinks located in areas other than kitchens where
receptacles are installed within 1.8 m (6 ft) of the outside
edge of the sink
Code05 is offline   Reply With Quote
The Following 2 Users Say Thank You to Code05 For This Useful Post:
frenchelectrican (10-05-2011), jbfan (10-05-2011)
Old 10-05-2011, 07:18 AM   #7
Licensed electrician
Rewards Points: 1,744
This would have been a perfect question for you to look up.
Code05 (10-05-2011)
Old 10-05-2011, 07:28 AM   #8
Code05's Avatar
Doh!!!
I blew that one.
Old 10-05-2011, 07:51 AM   #9
Originally Posted by Code05 View Post
Doh!!!
I blew that one.
How is the kid going to learn if the parents do their homework?
Old 10-05-2011, 08:09 AM   #10
Code05's Avatar
I know better..it was 5:30AM and I was not fully awake.
I made sure that he has access to the NEC, so no excuses that he left it at work.
Old 10-05-2011, 05:40 PM   #11
dmxtothemax's Avatar
Rewards Points: 5,486
Are you asking if it can be done ?
Or if the code allows it to be done ?
Cause yes it can be done ! BUT !
Is it safe to do so !
Maybe yes! maybe no!
dmxtothemax is offline   Reply With Quote
how to fix washing machine front spring rvegab00 Appliances 2 04-11-2012 03:30 AM
Trouble with washing machine drainage wfischer Plumbing 3 05-15-2011 05:10 PM
Washing machine and dedicated circuit.... ? CoconutPete Electrical 15 11-16-2010 08:02 PM
Tapping water line and drain from sink for washing machine? RyanD Plumbing 2 06-27-2009 08:25 PM
Hooking up a washing machine?? teachtech Plumbing 1 03-11-2008 11:17 AM
