Need 12 Volt DC To 120 Volt AC Inverter Recommendation - Electrical - DIY Chatroom Home Improvement Forum
Old 06-13-2010, 09:31 PM   #1
not-so-newbie
bobrok's Avatar
Send a message via ICQ to bobrok
need 12 volt DC to 120 volt AC inverter recommendation
I am looking to replace my inverter and want to ask what are the better, most efficient brands. My usage is pretty minimal. I need to run 2 - 3 CFLs of 14 Watts each and a small 13" digital TV off antenna for about 2 - 3 hours in the evenings at camp. I use a battery pack coupled to a solar charger and have enough power but the more I read about inverters the more choices I am finding and it's becoming confusing.
Right now I'm using a Radio Shack 350 Watt modified wave and it's done it's job well for 3 - 4 years but the fan is cracked and it is probably not worth replacing. Given my wattage needs I am wondering if my inverter is too large and running inefficiently. I know, that's a pretty small inverter to begin with but it cost quite a bit more than other comparable brands I've seen.
Does anyone have a recommendation as to what I should look at?
Thanks.
bobrok is offline   Reply With Quote
Old 06-14-2010, 09:25 AM   #2
Probably the inverters that put out a square wave are the most efficient but your equipment has to be able to tolerate this waveform.
http://www.google.com/images?client=...N&hl=en&tab=wi
PoCo puts out a more or less pure sine wave.
Hosfelt.com may have a replacement fan for a few bucks.
Tags
sizing inverter
12 Volt lighting AC or DC johnr9q Electrical 20 11-21-2010 01:12 PM
120 or 240 volt, difference in meter reading? forresth Electrical 4 06-01-2010 03:45 PM
240 volt load/appliance and ground vs neutral kgize Electrical 7 04-22-2010 11:40 PM
How to power a 120/240 volt 3 phase oven in a building with 120/240 volt single phase wantsomegetsome Electrical 9 05-04-2009 10:49 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
