Is It Necessary To Ground A Ceiling Box? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-16-2013, 01:41 PM   #1
Rewards Points: 1,062
Is it necessary to ground a ceiling box?
I know that it is necessary to ground an outlet box, I do it using green screws and there is a hole in the commonly found metal handy boxes that sits on a bump in the back of the box that the screw fits in.
But is it necessary to ground a ceiling box (for lights and fans)? None of the holes on this octagonal box pictured can fit such a screw.
Old 05-16-2013, 01:58 PM   #2
Yes, it is required to bond that box. If no hole will accept a typical 10/32 screw then you can either drill and tap your own hole or use a ground clip.
regvdd is offline   Reply With Quote
The Following User Says Thank You to regvdd For This Useful Post:
amakarevic (05-16-2013)
Old 05-16-2013, 02:07 PM   #3
Special User
Rewards Points: 1,230
That box looks like it might have a couple premade holes the right size to tap?
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
The Following User Says Thank You to tylernt For This Useful Post:
Old 05-16-2013, 02:20 PM   #4
Sorry, I'll take that back. The screw does fit in:
Old 05-16-2013, 02:24 PM   #5
Rewards Points: 12,868
Hope your not planing on installing a fan there, that's not a fan approved box.
Old 05-16-2013, 02:27 PM   #6
Oh no?
Old 05-16-2013, 02:30 PM   #7
Special User
I believe a non-fan-rated box can be used to mount a fan, if the fan has another separate method of securing to the building structure.
Old 05-16-2013, 02:31 PM   #8
Licensed electrician
Rewards Points: 1,034
That is a standard ceiling box. A fan box will have studs or bosses for the larger mounting screws for a fan.
Old 05-16-2013, 02:32 PM   #9
will this be OK?
http://www.lifeandhome.com/thomas-an...FUOe4AodB1kAzw
Old 05-16-2013, 02:34 PM   #10
Rewards Points: 506
Use this:
http://www.homedepot.com/catalog/pro...94a2d2_300.jpg
Installation is the Reverse of Removal.
Old 05-16-2013, 02:38 PM   #11
JW
mm11's Avatar
Rewards Points: 592
Also, if you're not going to use the other connectors shown in your pic, the NEC requires that those connectors be removed and the holes be covered with knock-out seals.
mm11 is offline   Reply With Quote
Old 05-17-2013, 07:56 AM   #12
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
There are several options .... new contruction we use the middle 2... usually the FAN RATED pancake .. look close at the screws ....
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Old 05-17-2013, 01:53 PM   #13
Here is what I had rigged up before I was told I needed a box with braces. Feels darn sturdy. But is it still against the code?
P.S.: never mind the lack of wire nuts, this is just a temporary hack
Old 05-17-2013, 02:05 PM   #14
Special User
It's legal if you screw the fan into the 2x4 and not just hang it from the box.
Old 05-17-2013, 02:18 PM   #15
thanks. i don't recon the design of many fans make that possible. so i will just go out and buy the proper box.
The Following User Says Thank You to amakarevic For This Useful Post:
Philly Master (05-17-2013)
Garage ceiling joists and beam question Truth Building & Construction 8 01-05-2012 08:52 PM
Fried electronics after earth ground accidentally disconnected oukachiru Electrical 7 07-12-2011 04:05 PM
How do you ground a ceiling fan installation involving a metal box? WillK Electrical 2 01-25-2011 09:41 PM
Ceiling fan wiring. Passes through and no ground. nimchimpski20 Electrical 6 11-12-2010 11:17 AM
Ceiling fan missing ground wire tigereye Electrical 3 08-22-2009 11:41 AM
