Is This A NEC Requirement? - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 09-19-2011, 04:44 PM   #31
Rewards Points: 150
Originally Posted by Code05
Actually that that is a good idea. In a polite way ask for the code section or amendment. Don't be pushy, just explain that you want to learn.
There many myths about the code and this is good way to find out.
Hey there was a big push on the job so I didn't get the chance to sit down and pick his brain. But I will do so tomorrow
Sunny B. is offline   Reply With Quote
Old 09-19-2011, 04:56 PM   #32
Rewards Points: 150
You still owe me an answer on grounding/bonding.
Hey Code05! You already gave me the article. What would that prove if I type article 250. 4. I'm aware that you know the code very, very well. I respect you for that and look forward to learning alot more from you. But nothing would come out of me copying what you wanted me to say from the start. You have to keep in mind, that I'm just starting to learn to navigate through the code. I usually just read text books(residential wiring, commercial wiring, understanding of the NEC, ect
Old 09-19-2011, 06:34 PM   #33
Code05's Avatar
Rewards Points: 1,104
Essentially, I want you to understand this:
GEC:
(1) Electrical System Grounding. Electrical systems that
are grounded shall be connected to earth
in a manner that
will limit the voltage imposed by lightning, line surges, or
unintentional contact with higher-voltage lines and that will
stabilize the voltage to earth during normal operation.
EGC:
(5) Effective Ground-Fault Current Path. Electrical equipment
and wiring and other electrically conductive material
likely to become energized shall be installed in a manner that
creates a low-impedance circuit facilitating the operation of
the overcurrent device or ground detector for high-impedance
grounded systems. It shall be capable of safely carrying the
maximum ground-fault current likely to be imposed on it from
any point on the wiring system where a ground fault may
occur to the electrical supply source. The earth shall not be
considered as an effective ground-fault current path.
This is my point. Understand?
Electricity is complicated, I will explain as best as I can. You are doing well, keep asking questions.
Code05 is offline   Reply With Quote
Old 09-19-2011, 07:04 PM   #34
Rewards Points: 150
GEC:
EGC:
Thanks. I appreciate it. And will do
Old 09-19-2011, 09:11 PM   #35
Rewards Points: 6,652
Derek, it is even more complicated, when dealing with shipboard power, in the way that the ground is the ship's hull. In turn, you have a electrode system to keep the darn thing from corroding at the same time, by the use of zinc plates along the hull. And add into that, you are using a three phase power system. Yes, my head hurt like the dickens after the first week of BEE school.
Old 09-20-2011, 05:56 AM   #36
Code05's Avatar
Yeah, I heard the Navy program was pretty tough. I have studied the systems a little and ship board systems are no piece of cake by any means.
AFCI breaker requirement Ranger31 Electrical 5 08-21-2011 09:07 PM
Vapor barrier requirement for finished basement JTK Building & Construction 13 02-05-2011 04:30 PM
Compost or top soil requirement cprao Landscaping & Lawn Care 10 12-28-2010 05:01 PM
Height requirement for boiler shutoff switch secutanudu Electrical 2 10-13-2010 07:28 AM
Panel Upgrade space requirement joshvette001 Electrical 4 05-02-2010 04:48 PM
