Is This A NEC Requirement? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-17-2011, 01:11 PM   #1
Rewards Points: 150
Is this a NEC requirement?
Hey guys!! This topic was started in another thread but to avoid changing the subject of that thread, we agreed to start a new one. In my days of being in this trade(3 years) we have always ran all of our home runs into our light, then to the switch when we were doing commercial work. Now I'm "almost" sure it's code but I can't find it. And not sure of weather it's NEC or NYC code. Can anyone help?
Sunny B. is offline   Reply With Quote
Old 09-17-2011, 02:40 PM   #2
Rewards Points: 6,652
Switch legs are fine. They actually save wire.
Old 09-17-2011, 02:41 PM   #3
Master Electrician
Rewards Points: 3,680
2011 NEC requires a grounded conductor at each SWITCH box with a couple of exceptions.
brric is online now   Reply With Quote
Old 09-17-2011, 02:53 PM   #4
Rewards Points: 150
You mean "switch loop"
Old 09-17-2011, 02:58 PM   #5
It is what ever you want call it. In the Navy, we called them suicide legs.
Old 09-17-2011, 02:58 PM   #6
Rewards Points: 150
I don't own the 2011 NEC yet, and NYC hasn't adopted it yet either.
Old 09-17-2011, 03:18 PM   #7
Rewards Points: 150
I don't see the significants of a grounded conductor in every switch box either
Old 09-17-2011, 03:32 PM   #8
Electrician
Rewards Points: 760
Most times you don't need it, but just think how much easier it will be in 10 years when the home owner decides he wants a timer instead of a switch.
darren is offline   Reply With Quote
Old 09-17-2011, 03:33 PM   #9
Rewards Points: 150
Good point!
Old 09-17-2011, 04:35 PM   #10
Licensed electrician
Rewards Points: 1,028
This is being done to allow the use of switching devices that may require a neutral like a timer, lighted switch or a smart switch. Apparently too many were using the grounding conductor when a neutral was required and the code panels did not want this to continue.
The grounded conductor is not needed if a conduit system is used and there is space for one to be installed later, or if one side of the wall is open to allow it to be added.
The Following 2 Users Say Thank You to Jim Port For This Useful Post:
frenchelectrican (09-17-2011), gregzoll (09-17-2011)
Old 09-17-2011, 04:59 PM   #11
Code05's Avatar
Rewards Points: 1,104
I hate this stupid new rule. If UL hadn't approved devices that used the grounding conductor as a neutral, The code panel would not have had to cave in and accept it.
Code05 is offline   Reply With Quote
The Following User Says Thank You to Code05 For This Useful Post:
Old 09-17-2011, 05:10 PM   #12
Just another example of the the panels needing to address something through the codes because untrained people, or uncaring, are installing things that should not have been installed until the correct wiring was installed. I see this as a design issue which the code says it is not a design manual.
I know technology will change, but still see this as wasteful by forcing an install that may never get utilized.
SD515 (09-18-2011)
Old 09-17-2011, 05:52 PM   #13
Rewards Points: 150
So no one knows the answer to my original question?
Old 09-17-2011, 06:03 PM   #14
It is not in the NEC.
Old 09-17-2011, 06:17 PM   #15
Rewards Points: 150
Yea I think your right Jim because I can't find it either. But I have a friend that works with Arc electric(which is a union shop) and he said that's the way they do it. So maybe it is just a jurisdiction thing
AFCI breaker requirement Ranger31 Electrical 5 08-21-2011 10:07 PM
Vapor barrier requirement for finished basement JTK Building & Construction 13 02-05-2011 05:30 PM
Compost or top soil requirement cprao Landscaping & Lawn Care 10 12-28-2010 06:01 PM
Height requirement for boiler shutoff switch secutanudu Electrical 2 10-13-2010 08:28 AM
Panel Upgrade space requirement joshvette001 Electrical 4 05-02-2010 05:48 PM
