NEC Question - High & Low Voltage In Same Box - Electrical - DIY Chatroom Home Improvement Forum
Old 02-11-2013, 08:04 AM   #1
NEC Question - High & Low Voltage in Same Box
Is there an exception in the NEC for a low voltage wire to be terminated inside a 120V single gang electrical box? I thought the NEC allowed it as long as all the insulators on the wires were rated for the highest voltage in the enclosure. So if my 12VDC wire was rated for say 250V I would be good right?
I have a SM120X relay module connected to my smoke detector. It has a relay with isolated contacts where I want to connect a low voltage wire. The relay coil is powered by 120V.
Are there any markings I need to add to the low voltage conductors? I can see this would be dangerous if someone later connected these to high voltage not knowing where they are connected.
blakemc is offline   Reply With Quote
Old 02-11-2013, 08:29 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,990
As long as the wire rating is rated for the highest voltage present you are fine.
I would not worry about what someone might do down the road. If they connect wires not knowing where they go or what they do it's their problem.
Question about small voltage between neutral and ground voodoochile Electrical 3 11-01-2012 08:16 PM
Can someone tell me why my low voltage lights are reading high current at the switch? kmc Electrical 5 06-04-2012 09:38 PM
Where can I find high voltage electrical supplies? Errigour Electrical 19 09-12-2011 05:20 PM
low voltage lighting question please.. melissadurante Electrical 1 03-02-2008 12:55 AM
Low voltage in same box as high voltage? mpedrummer Electrical 2 02-28-2007 11:49 AM
