NEC- National Electric Code 2008 - Electrical - DIY Chatroom Home Improvement Forum
Closed Thread
Old 02-26-2010, 07:07 PM   #1
NEC- National Electric code 2008
That means it applies to the entire country
Permits & Inspections are usually required for ALL electric work
It may not be legal for you to do your own work, Check with your local Building Dept
This thread will be added onto as a form of "Cliff Notes" for the NEC
If there is something that needs to be corrected, or if you wish to add to this thread; please let us know
The NEC is available online, you may have to sign up for an account to view it:
http://nfpaweb3.gvpi.net/rrserver/br...NFPASTD/7008SB
(may not be working)
Draft Version:
http://www.nfpa.org/assets/files/PDF...08ROPDraft.pdf
Also a link to State specific NEC/Building codes:
http://bulk.resource.org/codes.gov/
New Code book comes out every 3 years, it is not always fully accepted by States & sometimes not until 1-2 years later
Local codes can vary from the NEC
210.23 An individual branch circuit shall be permitted to supply any load for which it is rated (some think you can only load to 80%)
210.50 Required Branch circuits
14g wire is rated for 15a, 12g wire is rated for 20a
15a outlets ONLY on a 15a circuit
15a/20a are allowed on a 20a circuit
A single 15a receptacle is not allowed on a 20a circuit
AFCI protection is required almost every where under NEC 2008
Exceptions are GFCI required: bathrooms, kitchens, laundry (GFCI if sink within 6' of receptacle), garage & outside circuits
Bathroom requires a dedicated 20a GFCI protected circuit that can serve outlets in multiple bathrooms
OR
Outlets & Lights in One bathroom
Kitchen requires 2 dedicated 20a GFCI protected circuits for counter (no lights)
Laundry area requires a dedicated 20a GFCI protected circuit
Scuba_Dave is offline
The Following 5 Users Say Thank You to Scuba_Dave For This Useful Post:
alheim (02-13-2015), Contractormedic (07-12-2012), flashover600 (02-21-2011), hryser (03-08-2011), net2work (11-03-2012)
Old 02-26-2010, 07:23 PM   #2
SUB-Panels
Sub-panels:
Under NEC Code require 4 feeds: 2 hots, neutral & an insulated green ground
#6 & Under must be the correct color: White neutral, (usually) green ground - refer to 200.6 for options
Detached structure requires grounding rods connected with #6 Min
See 310.16 for wire sizing
Wire running underground must be rated for wet use, such as UF or THWN (in conduit)
Conduit fill calculator:
http://www.onlineconveyorparts.com/enghelp/conduit.htm
Some threads to review on sub-panel installations:
Wiring Garage for 220
Sub-panel
Sub-panel for basement (Full Kitchen, bath, theater)
Installing a subpanel
Old 03-05-2010, 09:37 AM   #3
Kitchen Wiring
Kitchen wiring
210.52 Required Branch circuits
Keep in mind that the NEC is the MINIMUM standards you must meet
In many cases it is MUCH better to exceed the code, especially in the kitchen where a lot of power hungry devices are used
(Each) Kitchen requires 2 dedicated 20a GFCI protected circuits for counter (no lights)
These shall be located no more then 20" above the countertop
Refridgerator - Good idea to have this on a dedicated 15/20a circuit, not required
Dishwasher - requires dedicated circuit, these can pull 12a or more
---garbage disposal can be on this circuit
Over the stove Microwave - many Mfg's require a dedicated circuit, if more then 50% of the circuit it requires a dedicated ciruit (210.23).
Local codes or Inspector may require a dedicated circuit
It makes sense to have a dedicated circuit for the MW & fan hood
Range hood requires a dedicated circuit if cord & plug (422.16)
--seems to be required now so that if a combo MW/Hood is installed there will be enough power
The Following User Says Thank You to Scuba_Dave For This Useful Post:
hryser (03-08-2011)
Old 03-05-2010, 09:42 AM   #4
Afci & gfci
AFCI GFCI - NEC 2008
GFCI 210.8
Exclusions for the Garage & Basement have been removed
AFCI 210.12
NOTE: The areas in red require GFCI protection
ruffroad (11-03-2010)
Old 03-08-2010, 01:53 PM   #5
Closet Lights
220.14 (D) Luminaires. An outlet supplying luminaire(s) shall be calculated based on the maximum volt-ampere rating of the equipment and lamps for which the luminaire(s) is rated.
NEC 410.16
NEC 410.8 (2005) is now 410.16 under NEC 2008
(B) Luminaire (Fixture) Types Permitted. Listed luminaires
(fixtures) of the following types shall be permitted to
be installed in a closet:
(1) A surface-mounted or recessed incandescent luminaire
(fixture) with a completely enclosed lamp
(2) A surface-mounted or recessed fluorescent luminaire
(fixture)
(D) Location. Luminaires (fixtures) in clothes closets shall
be permitted to be installed as follows:
(1) Surface-mounted incandescent luminaires (fixtures) installed
on the wall above the door or on the ceiling,
provided there is a minimum clearance of 300 mm
(12 in.) between the luminaire (fixture) and the nearest
point of a storage space
(2) Surface-mounted fluorescent luminaires (fixtures) installed
provided there is a minimum clearance of 150 mm
(6 in.) between the luminaire (fixture) and the nearest
(3) Recessed incandescent luminaires (fixtures) with a completely
enclosed lamp installed in the wall or the ceiling,
provided there is a minimum clearance of 150 mm (6 in.)
between the luminaire (fixture) and the nearest point of a
storage space
(4) Recessed fluorescent luminaires (fixtures) installed in
the wall or the ceiling, provided there is a minimum
clearance of 150 mm (6 in.) between the luminaire
(fixture) and the nearest point of a storage space
410.9 Space for Cove Lighting. Coves shall have adequate
space and shall be located so that lamps and equipment
can be properly installed and maintained.
Old 03-12-2010, 11:43 AM   #6
Conduit Fill
Conduit Fill
Conduit fill online Calculator: Bigger is sometimes better
No more then 360 degrees of bends between pull boxes
1 conductor/cable Max conduit fill is 53%
3 or more fill Max conduit fill is 40%
Look in Chapter 9 in NEC
Diameter Calculator to be used for cables:
https://edeskv2.belden.com/conduitcalculator/
Note this list is for cross section & calculator needs Diameter (being filled in)
Still looking for a reliable list of cable diameters for conduit fill
APPROX sizes are listed & may differ depending upon Mfg
One Mfg :http://www.encorewire.com/docs/Catalog-NM.pdf
Another Mfg :http://www.kerickind.com/documents/p...ductormain.pdf
AWG.........Diameter.....Cross section
14-2 NMB-----.390.......... .1018
12-2 NMB-----.450.......... .1320
10-2 NMB-----.493.......... .1917
8-2 NMB------.580.......... .2942
6-2 NMB------.695.......... .3664
14-3 NMB-----.320......... .0740
12-3 NMB-----.345. ....... .0946
10-3 NMB-----.430......... .1399
8-3 NMB------.555.......... .2507
6-3 NMB------.612.......... .3318
4-3 NMB------.820-----------
2-3 NMB------.945-----------
14-2 UF........................... .1405
12-2 UF........................... .1684
10-2 UF........................... .2107
8-2 UF............................. .3610
6-2 UF............................. .4657
14-3 UF........................... .2651
12-3 UF------.626-----------.3078
10-3 UF........................... .4151
8-3 UF............................. .8808
6-3 UF............................1.1747
Old 04-12-2010, 06:40 PM   #7
Pool & Spa Installations
Read section 680 for requirement
Section 680.26 for required Bonding grid around the pool/spa
680.22 requires a 15a or 20a GFCI protected circuit between 6' & 20' of the pool for general use
Old 04-19-2010, 04:41 PM   #8
Whole House Electric Load Calculation
Zip file attached is an Excel spreadsheet for calculating your whole house Power Load
Breaker Panel Clearance required:
The Following 2 Users Say Thank You to Scuba_Dave For This Useful Post:
ChrisDIY (11-29-2010), HighGlossPL38 (11-23-2013)
Closed Thread
Distance between Heater & Combustibles DIY_JC Building & Construction 7 01-20-2009 07:52 AM
Electric wire in cold air return bvbellomo Electrical 8 01-08-2009 06:01 PM
Electric tankless hot water heater former33t Plumbing 2 02-28-2008 11:40 AM
