NEC For Installing An Outlet In A Crawl-space? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-27-2010, 07:51 AM   #1
Rewards Points: 45
NEC for installing an outlet in a crawl-space?
I need to install a switched outlet in my crawlspace and would like to install it according to NEC but as a DIY'er I don't have the code book handy.
Main question is: do I need to use a GFCI outlet and or an "outdoor outlet assembly"? My crawl is dry and this will not be used for a sump pump. I plan to use it to power a 300W indoor / outdoor 12V magnetic transformer.
I appreciate your advice.
kooshball is offline   Reply With Quote
Old 03-27-2010, 08:10 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,948
Yes it needs to be a GFI or GFI protected.
No, it does not need an outdoor cover.
Old 03-27-2010, 09:05 AM   #3
Electrician
SD515's Avatar
Rewards Points: 504
You mention that it is to be switched. I would have it be fed from a GFCI breaker, or install a GFCI receptacle before the switch and have the switch control a 'regular' receptacle. Many GFI receptacles I've installed trip instantly when the power is first established. If you put the switch before the GFI, there's a chance it will trip when the switch is turned on. Check it first...might save you some headaches.
Kyle
Old 03-27-2010, 09:35 AM   #4
Rewards Points: 45
Good point, I might be lucky and find that it is already on a GFCI breaker as that same feed is switching several exterior line voltage fixtures. If I find that I am already on a GCFI breaker, do I need the GFCI outlet as well or is it already protected?
thanks
Old 03-27-2010, 11:58 AM   #5
Master Electrician
Rewards Points: 3,808
I've never had any problems with switched GFIC receps.
brric is offline   Reply With Quote
Old 03-27-2010, 02:50 PM   #6
" Euro " electrician
frenchelectrican's Avatar
Just becarefull where you get the GFCI circuit from and it should not be from either kitchen or bathroom both have GFCI and the codes do not allow that to be extended out of the " room "
I have no issue with switched GFCI reccetpales I know it will be pain in arse in first time but after that it will work just fine, but I rather run this in GFCI breaker and go to the switch then standard recetaplae and marked stated " GFCI protected " so you know it is on GFCI in case someone try to figure out why the recetpale do not work.
Merci,Marc
Old 03-28-2010, 11:13 AM   #7
Electrician
SD515's Avatar
Rewards Points: 504
Kooshball, if the line is already on a GFCI breaker then you do not need a GFCI receptacle, it's already protected. Marc, the frenchelectrician makes a good point about not using the kitchen or bath circuits.
Kyle
Old 03-28-2010, 08:15 PM   #8
electrical instructor
a GFCI rec is only required in a crawl space if it is at or below grade level. If this is not the case, a GFCI is not required per 210.8(4)
bhound84 is offline   Reply With Quote
Insulating crawl space jenoble99 Building & Construction 10 06-18-2009 12:09 PM
Vapor barrier for shallow crawl space? Jeremy Hillary Boob, PhD Building & Construction 8 03-24-2009 10:03 AM
Crawl space swamp, house on crap jacks. Denny's girl Building & Construction 2 03-09-2009 12:02 PM
insulating crawl space near plate measure thrice Building & Construction 13 01-26-2009 03:11 PM
Crawl Space needs "re-insulating" bigNY Building & Construction 1 10-12-2006 01:55 PM
