NEC And Hanging Fixture Wires - Electrical - DIY Chatroom Home Improvement Forum
Old 10-02-2012, 10:52 AM   #1
NEC and Hanging Fixture Wires
All the hanging fixtures/chandeliers in my house have bare non-insulated ground wires. Is this the standard in the National Electric Code? I have looked under fixtures Article 402 and have not been able to find where this is accepted.
teedoe is offline   Reply With Quote
Old 10-02-2012, 10:56 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 380
Just fine.
Old 10-02-2012, 10:59 AM   #3
Thank you for the quick response. Can you point me in the direction where it is stated in the NEC. I am rewiring a chandelier and want documentation to back up my work for having a non-insulated ground.
Old 10-02-2012, 11:06 AM   #4
jbfan's Avatar
Rewards Points: 380
I'm not sure you would find it in the nec, as this is a manufactures decision, and they have their own codes.
The Following User Says Thank You to jbfan For This Useful Post:
teedoe (10-02-2012)
Old 10-02-2012, 11:15 AM   #5
Thanks, do you know what codes they are regulated by?
Old 10-02-2012, 11:20 AM   #6
jbfan's Avatar
Rewards Points: 380
Can'y help you there, but they are made to some form of UL standard.
Is this something you are trying to sell?
Old 10-02-2012, 11:20 AM   #7
Licensed electrician
Rewards Points: 1,456
Why do you need documentation? Bare conductors are commonly used in grounding.
This may be covered in the UL White Book. IDK.
Old 10-02-2012, 11:20 AM   #8
I think I found it in NEC 400.22 A
Colored Braid. A braid finished to show a white or gray color and the braid on the other conductor or conductors finished to show a readily distinguishable solid color or colors.
Thanks for your help though.
Old 10-02-2012, 11:23 AM   #9
NEC 400.22 deals with the grounded conductor, not the grounding conductor.
Old 10-02-2012, 11:29 AM   #10
What is the difference between groundED and groundING?
Grounded = Neutral wire
Grounding = Path to earth wire
Old 10-02-2012, 11:36 AM   #11
The grounded conductor is the return path for the current. The grounding conductor is for safety should a wiring fault occur to a metal surface.
Old 10-02-2012, 11:36 AM   #12
Thank you for all your help
