-   -   NEC and Hanging Fixture Wires (http://www.diychatroom.com/f18/nec-hanging-fixture-wires-158693/)
teedoe 10-02-2012 10:52 AM
All the hanging fixtures/chandeliers in my house have bare non-insulated ground wires. Is this the standard in the National Electric Code? I have looked under fixtures Article 402 and have not been able to find where this is accepted.
jbfan 10-02-2012 10:56 AM
Just fine.
teedoe 10-02-2012 10:59 AM
Thank you for the quick response. Can you point me in the direction where it is stated in the NEC. I am rewiring a chandelier and want documentation to back up my work for having a non-insulated ground.
jbfan 10-02-2012 11:06 AM
I'm not sure you would find it in the nec, as this is a manufactures decision, and they have their own codes.
teedoe 10-02-2012 11:15 AM
Thanks, do you know what codes they are regulated by?
jbfan 10-02-2012 11:20 AM
Can'y help you there, but they are made to some form of UL standard.
Is this something you are trying to sell?
Jim Port 10-02-2012 11:20 AM
Why do you need documentation? Bare conductors are commonly used in grounding.
This may be covered in the UL White Book. IDK.
teedoe 10-02-2012 11:20 AM
I think I found it in NEC 400.22 A
Colored Braid. A braid finished to show a white or gray color and the braid on the other conductor or conductors finished to show a readily distinguishable solid color or colors.
Thanks for your help though.
Jim Port 10-02-2012 11:23 AM
NEC 400.22 deals with the grounded conductor, not the grounding conductor.
teedoe 10-02-2012 11:29 AM
What is the difference between groundED and groundING?
Grounded = Neutral wire
Grounding = Path to earth wire
Jim Port 10-02-2012 11:36 AM
The grounded conductor is the return path for the current. The grounding conductor is for safety should a wiring fault occur to a metal surface.
teedoe 10-02-2012 11:36 AM
Thank you for all your help
