NEC On Connector Clamps For Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 04-22-2013, 03:15 AM   #1
Rewards Points: 141
NEC on connector clamps for panel
Hi there,
I'm adding quite a few 12-2 (7 of them) and 14-2 NM cables (two) into the main panel.
Have a question on the NEC/UL code for connector clamp sizing on the main electrical panel.
What connector clamp type/size (e.g. 1/2" or other size KO) allows multiple NM cables (gauge size and how many), etc.
I have a bunch of 3/8" clamps w/ 1/2" KO, but I heard that size clamp only allows one cable to feed thru'. Is that true? Which type/clamp size would work w/ 2x 12-2 NM cables (or more)?
Thanks.
joemc3 is offline   Reply With Quote
Old 04-22-2013, 04:05 AM   #2
Licensed electrician
Rewards Points: 1,872
Many typical 1/2" NM clamps will allow for 2 flat xx-2 type cables. Check the package.
Old 04-22-2013, 05:21 AM   #3
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
http://www.aifittings.com/products/spec-sheets/NM94.pdf
These are great connectors, check out the PDF file for cables allowed in each connector.
The Following User Says Thank You to stickboy1375 For This Useful Post:
kwilcox (04-23-2013)
Old 04-22-2013, 05:49 AM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,990
Some even accept three 2-wire cables.
Old 04-22-2013, 05:53 AM   #5
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I haven't seen those, but I normally don't have the box to check for the ratings.
Old 04-22-2013, 06:30 AM   #6
I only know this because I checked online. I don't think I've ever looked at the box.
IMO if it fits it works.
The Following 2 Users Say Thank You to Speedy Petey For This Useful Post:
brric (04-22-2013), stickboy1375 (04-22-2013)
Old 04-22-2013, 07:22 AM   #7
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Also check out the T&B 3200 & 3201.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 04-22-2013, 04:30 PM   #8
E2 Electrician
I honestly cannot stand those connectors, they are a PITA, from install to removal...
Jim Port (04-22-2013)
Old 04-23-2013, 10:17 PM   #9
Well, didn't this post just make my day! My panel is full of those and I had speculated that they weren't necessarily acceptable for panel applications. However, rather than replacing outright (major pita too), I thought I would just wait for the subject to come up some day while surfing forums. Sure enough, about 10 years later, here it is!
kwilcox is offline   Reply With Quote
Old 04-24-2013, 10:25 AM   #10
Rewards Points: 141
BTW, which kind of connector/clamp would take 3 cables? The NM94/NM95/NM96 can only take 2 cables max.
Old 04-24-2013, 10:35 AM   #11
electures's Avatar
I like them and have even using the for over thirty years without problems. To each their own.
