NEC On Conduit Vs Exposed For Basement - Electrical - DIY Chatroom Home Improvement Forum
Old 04-24-2013, 08:16 PM   #1
NEC on conduit vs exposed for basement
Hi, I have a basement that is not finished nor do i plan on finishing it. I have 2 outlets that I want to put on the same circuit that are on opposite sides of my basement(one by my work bench and one for a tv/space heater). My question is whether it is to code to just nail a 2x4 to the joists against the wall and then staple the exposed wire to the 2x4 down to where i want the receptacle OR do i have to run thhn wire in conduit? If the latter and i am pulling the 12 gauge nm wire through the joists from the electric panel to where i want to drop vertically down the wall how do you tie the thhn wire that will be in the conduit with the exposed 12 guage nm wire that is exposed through the joists? Im guessing a junction box? Also do you put a ground wire through the conduit? Everything i am seeing looks like the nm gets grounded to a box and they run just hot and neutral through the conduit. I dont see how you can have a gfi outlet with out a ground. Thanks in advance for any help.
bigpoppadiesel is offline   Reply With Quote
Old 04-24-2013, 09:07 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
You can do either as far as the NEC is concerned... just needs to be protected from physical damage, personally, as long as you are not having a axe wielding competition in your basement, stapling exposed NM to a 2x4 is perfectly fine.
Old 04-24-2013, 10:20 PM   #3
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
The problem is that "subject to physical damage" is a widely interpreted phrase. The inspectors in my area would require the NM to be sleeved. The east coast seems to be more liberal with their interpretation.
Old 04-24-2013, 10:23 PM   #4
E2 Electrician
I have to agree with your statement, i'm so happy I live in real world on the east cost though... In all my years doing this, I don't recall ever going to a service call where I had to replace an existing exposed cable due to physical damage.
The Following User Says Thank You to stickboy1375 For This Useful Post:
Philly Master (04-25-2013)
Old 04-24-2013, 11:13 PM   #5
Electrical Enthusiast
Rewards Points: 504
Maybe there are more axe-wielding competitions on the east coast?
Kyle_in_rure is offline   Reply With Quote
The Following User Says Thank You to Kyle_in_rure For This Useful Post:
Old 04-25-2013, 04:16 AM   #6
Electrical Contractor
kbsparky's Avatar
Nah ... they use pressure cookers these days ....
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
electures (04-25-2013)
Old 04-25-2013, 06:59 AM   #7
Thanks for the help!
Total Degrees of Bend in Underground PVC Conduit tedallen Electrical 12 03-29-2012 09:02 PM
Can I run several circuits through the same conduit? JeepNick Electrical 19 02-16-2012 04:47 PM
Running conduit from basement to the standalone garage sheslostcontrol Electrical 10 10-23-2010 01:22 PM
Sheathing/siding around conduit destroyer427 Building & Construction 1 10-20-2009 06:25 PM
ground wire in rigid conduit measure thrice Electrical 3 02-03-2009 06:25 AM
