-   -   NEC on conduit vs exposed for basement (http://www.diychatroom.com/f18/nec-conduit-vs-exposed-basement-178022/)
bigpoppadiesel 04-24-2013 08:16 PM
Hi, I have a basement that is not finished nor do i plan on finishing it. I have 2 outlets that I want to put on the same circuit that are on opposite sides of my basement(one by my work bench and one for a tv/space heater). My question is whether it is to code to just nail a 2x4 to the joists against the wall and then staple the exposed wire to the 2x4 down to where i want the receptacle OR do i have to run thhn wire in conduit? If the latter and i am pulling the 12 gauge nm wire through the joists from the electric panel to where i want to drop vertically down the wall how do you tie the thhn wire that will be in the conduit with the exposed 12 guage nm wire that is exposed through the joists? Im guessing a junction box? Also do you put a ground wire through the conduit? Everything i am seeing looks like the nm gets grounded to a box and they run just hot and neutral through the conduit. I dont see how you can have a gfi outlet with out a ground. Thanks in advance for any help.
stickboy1375 04-24-2013 09:07 PM
12 Attachment(s)
You can do either as far as the NEC is concerned... just needs to be protected from physical damage, personally, as long as you are not having a axe wielding competition in your basement, stapling exposed NM to a 2x4 is perfectly fine.
k_buz 04-24-2013 10:20 PM
The problem is that "subject to physical damage" is a widely interpreted phrase. The inspectors in my area would require the NM to be sleeved. The east coast seems to be more liberal with their interpretation.
stickboy1375 04-24-2013 10:23 PM
12 Attachment(s)
I have to agree with your statement, i'm so happy I live in real world on the east cost though... In all my years doing this, I don't recall ever going to a service call where I had to replace an existing exposed cable due to physical damage.
Kyle_in_rure 04-24-2013 11:13 PM
Maybe there are more axe-wielding competitions on the east coast? :thumbsup:
kbsparky 04-25-2013 04:16 AM
Nah ... they use pressure cookers these days ....
bigpoppadiesel 04-25-2013 06:59 AM
Thanks for the help!
