NEC Code - Where To Get? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-10-2007, 02:37 PM   #1
NEC Code - Where to get?
I have read a number of times people referring to the NEC regarding codes and/or violations. However, nothing comes up when I do a search on this site. Very strange!
Does anyone know where I can get a FREE copy of the NEC? I would hate to buy one if I only need one answer. I have Googled the NEC and keep getting results to buy it.
I have GCFI outlet in my garage and the refrigerator that we put out there keep tripping it when it comes on. I would like to refer to the NEC if running a heavy-duty extension cord to the garage door opener outlets(non-GCFI) that is on the ceiling is kosher.
Dallas is offline   Reply With Quote
Old 12-10-2007, 04:04 PM   #2
Rewards Points: 16
As far as i know there is no free nec. I believe you can put a dedicated outlet for the fridge and it doesn't have to be gfci protected but i'm not positive, hopefully someone will answer this for you. Barnes and noble has the nec code books and you can go there and read them all you want for free!
ponch37300 is offline   Reply With Quote
Old 12-10-2007, 04:13 PM   #3
Electrician philosopher
That is NOT TRUE!!! Let me consult my computer expert and I will return with a link (hopefully, if I can figure it out) that will get you the 2005 and the 2008 for free.
I don't think you can run an appliance cord that far. How old is the fridge? There is a chance the GFCI is tripping for a good reason.
Andy
Andy in ATL is offline   Reply With Quote
Old 12-10-2007, 04:15 PM   #4
greengiant's Avatar
NEC from the NFPA
The current code is on line at:
http://www.nfpa.org/itemDetail.asp?c...ookie%5Ftest=1
If you want access to previous versions you have to pay a fee for online access.
greengiant is offline   Reply With Quote
Old 12-10-2007, 04:30 PM   #5
Electrician
Here is EVERY nfpa code book...
http://www.nfpa.org/aboutthecodes/li..._standards.asp
chris75 is offline   Reply With Quote
Old 12-10-2007, 04:58 PM   #6
You guys are the best.
Andy
Old 12-10-2007, 05:18 PM   #7
Thanks for the links, everyone.
The refrigerator is around 4 yrs old. I was adviced to bypass the GCFI outlet but wanted to make sure it was not a violation. The distance is only a few feet from refrigerator to garage door outlet. I would run it straight up on the wall(8ft?) then straight to the outlet(3ft).
Old 12-10-2007, 05:45 PM   #8
Woodworker and Contractor
Kingfisher's Avatar
Rewards Points: 150
GFI go bad all the time , you could try replacing it first
Kingfisher is offline   Reply With Quote
Old 12-10-2007, 05:47 PM   #9
I just realized that i forgot to mention that it also trips the breaker.
Old 12-10-2007, 06:56 PM   #10
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,866
Just a comment.
The NEC is not a book you just pick up and get a quick answer. Not unless you are very versed in reading it. Even then, we sometimes stumble to find what we want.
The NEC is also not a "how to" book. The Handbook on the other hand is a very good resource for folks looking to learn and have things somewhat explained in layman's terms.
I still use the Handbook 99% of the time over the regular code book.
Neither book is worth buying unless you need it on a regular basis.
Old 12-10-2007, 07:06 PM   #11
Dallas, A GFCI trips between .004 and .006 Amps difference between the hot and neutral. Just barely below what will kill an adult male. A breaker trips at tens of thousands of what will kill an adult male. You need to investigate this further. More info, please...What else is on circuit, does anything else trip the circuit, if you take an extension cord and run it to another circuit, does it trip that one? You have a situation that MAY or may not be dangerous. Don't be walking in no puddles to get a beer out of this fridge.
Which trips, Dallas.... the breaker or the GFCI? Or sometimes one and sometimes the other?
One concern I would have is a bad GFCI in concert with a ground fault. Rare but bad combo.
Andy
Old 12-10-2007, 10:50 PM   #12
Sorry for not being clear in my intial post. Thanks for everyones patience.
I have plugged the refrigerator directly to the GCFI outlet(no extenstion cord) and it works fine for awhile. We have left our home a few times to return and find that the refrigerator is not working and noticed that it has tripped the breaker and the GCFI.
Breakfast room, family room, laundry room and garage are on the same circuit. I have not noticed anything else that trips the breaker. I have used a jigsaw in the same GCFI outlet and it is fine.
I think I should try to connect it to other circuits but I would hate to get fried. Electricity makes me nervous.
What's the ICC Electrical Code? Chuck Electrical 7 02-20-2013 11:19 AM
Code requirement to replace bathroom window. Rem8 Building & Construction 5 06-16-2008 03:57 PM
underground code tom b Electrical 8 03-23-2008 11:55 AM
Another Bryant 383KVA with code 31 problems rpgIVguru HVAC 1 02-05-2007 02:47 PM
code question JustJoe Building & Construction 3 01-27-2007 10:06 AM
