#1 |
NEC code for runnings wires with joist, not through
I need to run about 3 or 4 wires along the length of a joist. In the old days, they'd just stack these and wire staple them... I vaguely remember something about don't do that anymore, and to use a stacking clip? The only ones I can find at stores are the ones for 2x4 joists that are offset with a plastic clip that goes over the front of the stud so the wires are in the middle of the stud...
what do you do for a 2x10 joist? Just cut off the plastic end clip and place on the joist? something else? thanks!
House Information: Build 1996, 1500 sq ft basement, 1500 sq ft 1st floor, 800 sq ft 2nd floor, 560 sq ft unfinished attic space on 2nd floor. Insulation: Attic blown fiberglass, walls R-19, Basement R-19. HVAC: Trane xc95m fully modulating furnace, single zone, Trane XL20i commiunicating AC unit, TCONT900 Communicating thermostat. |
#2 |
Licensed electrician
You could just staple the stacker higher up on the joist or install them the same as on a 2x4. The proper clearance will be maintained.
Answers based on the National Electrical Code. Local amendments may apply. Check with your local building officials. |
#3 | |
NEC code for runnings wires with joist, not throughQuote:
| Display Modes | |
| Retrofitting Ground Wires - To Code!? | Thadius856 | Electrical | 21 | 07-11-2011 05:25 AM |
| Can't find the wires! | brianmarsh | Home Theater | 2 | 01-24-2010 08:11 AM |
| hooking up dryer....bronx ny code | SURFBUG | Appliances | 6 | 10-14-2008 10:41 PM |
| 1950's Roof Framing Strength | KempLN | Building & Construction | 21 | 06-17-2006 11:06 AM |
| Any way to allow a 3.5" bore through a 2x10 floor joist? | peeks | Building & Construction | 1 | 07-06-2005 03:02 PM |
