-   -   NEC code for runnings wires with joist, not through (http://www.diychatroom.com/f18/nec-code-runnings-wires-joist-not-through-153509/)
BlueBSH 08-13-2012 09:24 AM
I need to run about 3 or 4 wires along the length of a joist. In the old days, they'd just stack these and wire staple them... I vaguely remember something about don't do that anymore, and to use a stacking clip? The only ones I can find at stores are the ones for 2x4 joists that are offset with a plastic clip that goes over the front of the stud so the wires are in the middle of the stud...
what do you do for a 2x10 joist? Just cut off the plastic end clip and place on the joist? something else? thanks!
Jim Port 08-13-2012 10:07 AM
You could just staple the stacker higher up on the joist or install them the same as on a 2x4. The proper clearance will be maintained.
BlueBSH 08-13-2012 10:12 AM
thanks, just didn't know if that was perfered or not :)
