NEC code on rewiring?
I’m going to rewire a house I just purchased that was built in 1948. I’ve already paid an electrician to pull and update my service. The rewire will not be hard because the old plaster walls needed to come out so it looks like new construction except the exterior walls. I’ve attempted to do some research on what NEC code says about rewiring with no luck. I do have a question if someone can help me out. Many thanks in advance.
Question: When running the wire horizontal through the studs, a metal plate must cover where the wire run is so that a nail can’t penetrate. This is no problem on an interior wall where the metal plate can be mounted on both sides of the studs, but what about the exterior walls? What will keep a nail from being driven into the wire from the outside? Thanks, Dave |
There are "rules" on the penetration depth of nails used on the exterior, just for that reason,
what those rules are, i have no clue :) I'm just waiting until all the exterior is done! |
No way to go over all the requirements but if this is a total rewire then it will basically need to be up to the latest NEC code that your local juristiction recognizes.....probably 2002 or 2005. You need your permits and inspection schedule. Your local codes department should have a guide to help you out.
As for the horizontal runs through wooden studs you don't need a nail plate at all if the wire is not closer than 1 1/4" from the face of the stud. So a center drilled 5/8" hole in the stud will keep you from having to use nail plates with a tad to spare. Below is a guide for requirements to meet 2005 code, this is only for your reference to get you started thinking right. Get yourself a book on residential wiring and bone up. Knowing the requirements is not necessarily knowing how to wire them. Dont forget your smoke detector rules. Copied section IRC..... Smoke detectors are required in each sleeping room, outside of each sleeping room, and in each additional story including basements and cellars but not crawl spaces. Where more than one smoke detector is installed to meet these requirements, all smoke detectors within the dwelling unit require an interlock or interconnection in a suitable manner that upon activation of one, all alarms will be activate Make sure you can do this without being a licensed electrician. Cover your bases (rearend). The liability doing this without inspection would be unacceptable. Stubbie http://www.longbeach.gov/plan/h4hb/e...ode.asp#ground and this may help but is very detailed for new constuction http://www.selfhelpandmore.com/homew...dwel/index.htm |
Thanks Stubbie for your comments. I just picked up my permit today for plumbing and electrical, so I'm doing things the legal way and right way. Thanks for the concern. Also, great thougth to find out if my area uses 2002 or 2005. I just assumed everybody was using 2005.
I've been looking for books - do you have any recommendations? Just a little more info. Right now the house is wired with all the recepticles wiring coming up from the crawl space and the lighting is in the attic. I thought about using the same paths, but didn't know if the NEC would allow that. Any thoughts? Dave |
You can find it locally for less. Try your local bookstore or trades bookstore. Quote:
Watch your loads don't get too much on your breakers. AC, microwave over range, range, dishwasher are seperate individual branch circuits. Know where your going to have to gfci and afci. Get up to speed on your bathroom, bedroom, kitchen and laundry room code requirements as to gfci,afci , smokes, and the 20 amp branch circuit rating requirements in some of those rooms. Example... the kitchen minimum is two 20 amp branch circuits and they both have to show up on the countertop receptacles. Cauldwells book will tell you all the requirements and how to run the cables and how to fasten them. Such as only two cables under one staple and within 12 inches of a box etc.... Well I could go on and on. Maybe others will add. Good Luck Stubbie |
Another excellent book to recommend: Electrical Wiring: Residential by R. Mullin
To add to what Stubbie said: Map out your circuits, drawings and colored pencils are a great help, as is marking on the stud next to the box. Use 14ga for your lighting and 12ga for your receptacles. Double check that your "home runs" are done before closing the walls up. Add more receptacles than the minimum required. |
Stubbie, you gave the best single description I've read in along time. I wish I'd put in the adjustable boxes in the kitchen...oh well, next time.
Could you explain this a bit further? Quote:
Once again, thanks Stubbie!!!! I agree with RippySkippy - that description was great. I'll have some books by the end of the week.
Thanks again... |
Two things it keeps your wiring in the walls (in dave's situation) and not run thru the attic. Having a neutral in the box lets you grab power in an easily accessible location for further additions or last minute changes. Many devices that install in place of a normal switch require neutrals. It simply gives you more options without rewiring. I would also add that anywhere where you think you might add a ceiling fan someday I would go ahead and wire it up with 14/3 or 12/3 put a double gang box in and cap off the red wire, install a single gang cover and single pole switch. Then if you ever add that ceiling fan just install a double gang cover and add your second switch for the light and connect the switched leg to the red wire. Same thing in baths you never know what your going to change as for ceiling installed fans and lights. If you wire for the future it makes it a pretty simple deal and not much extra cost for one extra wire. Your undoubtly going to need a roll of 3 conductor cable so might as well make good use of it instead of throwing a hundred feet of it up on the self in the garage.
Househelpers advice about mapping the circuits is invaluable especially after you close things up . Now you can reference what wires go where and it may even be required for inspection. Stubbie |
All right Stubbie I'm with ya.
In addition to the sketching, digital pictures are especially helpful after the drywall goes up. |
Digital Pictures....Hmmmm...that is a great idea!!
Stubbie |
Okay, I started pulling out the old wire today. Everything went great. I did notice something today that could hinder my rewire job. The house was built in 1948 and in the corner of every wall (interior and exterior) is 4x4 studs. The 4x4 studs are butted up against each other. This will hinder me from running the wire around the perimeter of the room through the studs.
The only thing I can come up with is to drill either a 1" or bigger hole in each then fish it through. If I do this there will be tight curve in the wire. Has anyone ran into this before or have any other suggestions? I guess if I can't run it through the corners, all of the wire will be dropped down from the attic. Many thanks in advance, Dave |
You can drill a hole as you propose or cut/chisel a channel in the surface to route the wires through. In either case you will need to use nail plates to protect the wire. Just don't make the radius of the curve too tight. Or you can go up (through the top plate) and over to get around the corners.
Thanks HouseHelper for the reply-
Is there a code or a "suggested" code on how tight the curve/radius should be in the corners? Thanks, Dave |
Yes, but it usually is never an issue, but for your reference NEC Art. 334.24 states as follows
In your case you have no void but this is the general idea. Use auger bits to drill your studs. Don't use spade bits. http://www.rd.com/images/tfhimport/2...e003img002.jpg http://www.rd.com/images/tfhimport/2...e003img004.jpg Dont' drill great big holes in the studs or 4x4's. In your case it looks like you have true 4" studs so measure in 1 1/4" from the inside face and 1 1/4" from the outside face your hole cannot be any bigger than the distance between the marks, if center drilled to avoid nail plates. Or another way to look at it is for load bearing and non-load bearing walls holes cannot be bigger than 40% of the stud diameter or approx. 1 1/2" in your case center drilled. Doubled studs can be drilled at 60% of diameter. This is a typical example of a guide available from codes department http://www.mlec.com/Homeown.htm Stubbie |
| All times are GMT -4. The time now is 04:57 PM. |
