NEC Check - Electrical - DIY Chatroom Home Improvement Forum
Old 08-16-2009, 10:57 PM   #1
NEC check
can someone tell me if everything of the folloing is up the NEC:
This is a third apartment on the thrid floor
Let me know what you guys think of this And if you see and code blunders
BR 1] (AFCI protected)
I have a bedroom with 5 outlets and a swith and light- another outlet dediated for AC.
Outside:
220 line running to outside for Air Conditioning unit
Bathroom:
with 1 GFCI outlet and 1 light
Bedroom 2 (AFCI protected)
5 outlets and a light
Kitchen/pantry/ living room(AFCI protected)
1 small appliance branch for the pantry which has 2 outlets
1 small appliance branch for the kitchen outlets
dedicated dishwasher outlet
Living room :
6 outlets(inluding stove and hood) and a light
/countertop outlets 24 inch apart- general outlets 6ft apart/
oh and by the way, everything is on a 20 amp fuse with a 12/2 bx
bobward is offline   Reply With Quote
Old 08-17-2009, 09:28 AM   #2
  • You don't mention any GFCIs for the kitchen countertop receptacles. Any receptacle serving a kitchen countertop or that is within 6 ft of the outer most edge of a sink in a laundry, utility, or wet bar area also requires ground-fault protection. 2008 NEC 210.8(A)(6 and 7)
  • You need a receptacle for that open wall space near the pantry area - any wall space 24" or wider requires a receptacle so that no point along the wall space is more than 6' away (measured horizontally along the floor line). 2008 NEC 210.52(C)(1).
willis
Willis
williswires is offline   Reply With Quote
Old 08-17-2009, 10:46 AM   #3
Electrical Contractor
kbsparky's Avatar
You need at least 2 small appliance circuits for the receptacles serving the kitchen counter-top areas.
-KB
Old 08-17-2009, 02:12 PM   #4
Does the pantry have a counter?
If so then that can be considerd part of the kitchen
In that cas eif it has a seperate circuit serving only that counter it could count as the 2nd required kitchen small appliance circuit
Old 08-17-2009, 06:47 PM   #5
do i need the two small appliance circuits in the kitchen specifically. Or can I have them in the kitchen and then in the pantry like i have? And of course all the kitchen outlets are going to be GFCI
Old 08-17-2009, 06:48 PM   #6
willis
THANK YOU!!! i completly over looked that wall!
Old 08-17-2009, 06:53 PM   #7
If the pantry has a matching counter to the kitchen then it may be considered part of the kitchen & that may meet code. Might be the Inspector's call
If the pantry has a door to enter, then it will not count
Old 08-17-2009, 07:16 PM   #8
Thank you. It will have a matching counter. The spaces blend together, I hope that it will fly with the inspector, dont see why not. I will look through the book to see if there are any definitions for "pantry"
Old 08-17-2009, 07:22 PM   #9
What I would do is run (at least) one outlet to the kitchen counter from the pantry circuit
Then you are covered
Old 08-17-2009, 07:39 PM   #10
I love the dollar sign as the switch symbol
I occaisionally draw them that way to get a rise out of customers.
220/221 is offline   Reply With Quote
Old 08-17-2009, 07:42 PM   #11
Thank you greatly! What I will do is put the outlet where the refridgerator is going to be plugged into on it as well.. I believe the code extends rights to refriderators being plugged into the small appliance branch
Old 08-17-2009, 08:30 PM   #12
ok this is my updated drawing
Old 08-17-2009, 08:35 PM   #13
I'm pretty sure you need the 2nd circuit actually on the counter top, not just the fridge
Old 08-17-2009, 09:03 PM   #14
hmmm in that case, i guess ill go the trusty 12/3 way and just do every other on lets say black and the remaining on red. this way both branches are present everywhere
Old 08-17-2009, 11:33 PM   #15
or i might just extend the refridge outlet to one of my counter top outlets
check valve question burr HVAC 3 11-30-2008 11:03 AM
Sewage Lid + check valve majorchamp Plumbing 2 07-07-2008 11:06 AM
Question about sump pumps and check valves lennyseleven Plumbing 3 11-08-2007 11:33 AM
