NEC - 348.10 /12 -What Is An Exposed Location... - Electrical - DIY Chatroom Home Improvement Forum
Old 11-08-2008, 04:19 PM   #1
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
NEC - 348.10 /12 -What is an exposed location...
Code clarification please;
348.10 /12 -What is an exposed location that is not subject to physical damage?
If I have a piece of flexiable conduit that I run to my panel and it runs down the wall next to the panel (on the board the panel is mounted) to and connects in the side of the panel, doesn't that expose it to physical damage and violate the code?
Does BX / all flexiable EMT/ENT need to transition to ridgid before it would drop down below the joists to your panel?
Thank You kindly;
Jamie
jamiedolan is offline   Reply With Quote
Old 11-08-2008, 05:04 PM   #2
Electrician
"Subject to physical damage" is a completely ambiguous term and is not defined in the NEC.
The code leaves this determination completely to the discretion of the authority having jurisdiction or their representative (usually the wiring inspector)
You can try to use common sense as to what locations may be subject to physical damage, but if you have a situation that you suspect as questionable, you may want to call the inspector and see what they will be expecting from you to pass inspection.
To answer your initial question, no, rigid is not usually necessary below joists in a residence.
EBFD6 is offline   Reply With Quote
Old 11-08-2008, 05:30 PM   #3
DIY'er
jamiedolan's Avatar
That's good to know that it is not necessarily prohibited to use flexiable to the panel, but disappointing to know that it is up to the discretion whatever inspector comes out that day to decide if the flexiable ENT running down the couple feet of the wall to my panel is legal or not.
Jamie
Old 11-08-2008, 05:39 PM   #4
Electrician
Jamie
Subject to physical damage is typically only an issue industrial applications, or areas subject to vehicle traffic (like on the outside of your house near a driveway, or in the garage), etc..
The chances that the area above your panel is "subject to physical damage" are pretty low, I would be 99.9999% positive that you will be fine with romex, mc, emt, fnmc or any other wiring method in your situation.
Old 11-08-2008, 06:19 PM   #5
Electrician
Its a regional thing, here in the northeast there really never is a problem with protection from physical damage, here is a panel setup I did, notice the exposed SER cable on the right hand side. This would never be allowed in other parts of the US.
chris75 is offline   Reply With Quote
Old 11-08-2008, 06:26 PM   #6
Very nice work chris! Looks nice and clean. Whats the panel on the right? Is it a data cable distribution center?
rgsgww is offline   Reply With Quote
Old 11-08-2008, 06:36 PM   #7
DIY'er
jamiedolan's Avatar
Looks like top knotch work Chris. In other area would you have run that same service entrance cable in EMT?
Is that a commercial setup or a really large home?
Jamie
Old 11-08-2008, 06:41 PM   #8
Electrician
Its actually the feeder from the generator, but to answer your question, not around here, its not required to be protected.
The service is a 320 amp, the feeders actually come in through the back of the panels.
Jamie
It was a large home, actually the biggest 2 bedroom house I ever wired, it was a post and beam, money was no object on this job either, Everything was high end stuff.
Old 11-08-2008, 07:42 PM   #9
Let me guess...they ran rg/11q to the tvs?
Old 11-09-2008, 09:14 AM   #10
Electrician
"They" would be me, and I only ran rg6 to the tv's, but I did run rg11 out to the demarc from the basement, it was a pretty long run, the funny thing is this driveway is about a mile long, so the owners refused to pay the cable company for the line coming off the street, ended up with satellite, and internet from the phone company.
Old 11-09-2008, 09:18 AM   #11
Electrician
Yes, it was spec'd by the architect, but I refuse to use the inside guts, the box just makes it nice looking.
Mounting Ceiling Fan to Exposed Beam zero1niner Electrical 7 05-05-2009 11:41 AM
Concrete Walkway with Exposed Aggregate BTn5qsc2zB93ztGN9vJP Landscaping & Lawn Care 4 08-22-2008 07:49 AM
partially exposed rafters rtoni Building & Construction 1 08-13-2008 04:45 PM
Outdoor Speaker location jelly Home Theater 6 06-20-2008 03:10 PM
L/R Drain bath/shower over center drain location in floor? tigerbalm2424 Plumbing 2 12-04-2007 01:26 PM
