NEC 2008 Code Cycle - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-05-2008, 07:02 AM   #16
" Euro " electrician
frenchelectrican's Avatar
Originally Posted by Speedy Petey View Post
What code cycle are you under?
Maybe your area does not require AFCIs.
Don't automatically assume you are under the newest codes.
Pete.,, Jamesdolan is in Wisconsin.
And state of Wisconsin is still on 2005 NEC with optinail AFCI on bedroom circuits but the 2008 NEC code will be in effect in spring of 2009. { not sure excat date yet }
His home is only half hour away from my location.
Merci,Marc
Oh by the way Jamesdolan when you got the permit for that year the codes will be in effect for that code cycle.
Old 10-05-2008, 08:05 AM   #17
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,876
Thanks Marc. Good info.
Old 10-05-2008, 11:56 AM   #18
Registered User
Termite's Avatar
AFCI's aren't an option in sleeping areas under the 2005 NEC, unless the state made amendments to the code. AFCI's were required to be phased in by 2001 in the 1999 NEC...Gotta have them in the sleeping areas.
Of course that's only going to apply to a total re-wire, remodel, or new construction.
Old 10-05-2008, 01:11 PM   #19
Electrician
Originally Posted by J. V. View Post
I thought it was Ark Fault just for bedrooms.
I only use Ark Fault breakers when we are expecting a lot of rain, otherwise I think the Arc Fault breakers work much better.
That being said It's my opinion that AFCI's are required on new circuit installations only, and are not required to be installed on existing installations such as service changes.
Whether they are required only in bedrooms, or in the other portions of the house as well, will depend on the code cycle that is in effect in your area.
EBFD6 is offline   Reply With Quote
Old 10-05-2008, 07:42 PM   #20
KC.,
That is true and that why our state did wrote in a optional and most of the electricians don't bother run the AFCI at all incluiding myself I am not too crazy with early AFCI breaker due some issue before but I do understand the latter models should be alot better than early one were.
Merci,Marc
What's the ICC Electrical Code? Chuck Electrical 7 02-20-2013 11:19 AM
Stairway landing code question. Bcoleman6 Building & Construction 4 06-26-2008 10:43 AM
Another Bryant 383KVA with code 31 problems rpgIVguru HVAC 1 02-05-2007 02:47 PM
